Datagrid and Map from JSON web service.
6131
5
01-27-2015 08:38 AM
BrianPaulson1
I was able to duplicate this example: Feature collection | ArcGIS API for JavaScript
using point data in a SQL Server Table (Web service which returns Json format data from SQL Server).
I wanted to take the Feature collection example a step further where I could add a interactive datagrid/map that is similar to this example: Add zoom button to DataGrid .
First, is a interactive datagrid/map possible from a Json feature collection?  All the examples I find require a feature layer that is on a spatial server.  If so, could someone please point me in the general direction to how this can be accomplished.  Sorry I am new to this and might have asked something really basic.  Any help would be greatly appreciated since I have spent a lot of time trying to figure this out.  Thanks
JakeSkinner
Esri Esteemed Contributor
Hi Brian,
It's possible to populate a datagrid with a feature collection (see below).  The one thing I am having trouble figuring out is how to zoom to the feature.
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the
    samples on iOS devices-->
    <title>Flickr</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dojo/resources/dojo.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/dgrid/css/dgrid.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
      .dgrid { border: none; height: 100%; }
      .dgrid-column-0 {
        width: 35px;
      .dgrid-row-odd {
        background: #FFFDF3;
      td div img:hover {
        cursor: pointer;
    </style>
    <script>var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://js.arcgis.com/3.12/"></script>
    <script>
      var map, grid;
      require([
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/dijit/PopupTemplate",
        "esri/request",
        "esri/tasks/query",
        "esri/geometry/Point",
        "esri/graphic",
        "dojo/on",
        "dojo/_base/array",
        "dgrid/OnDemandGrid", "dgrid/Selection", "dojo/store/Memory",
        "dijit/form/Button",
        "dojo/parser", "dojo/_base/declare",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane",
        "dojo/domReady!"
      ], function(
        Map,
        FeatureLayer,
        PopupTemplate,
        esriRequest,
        Query,
        Point,
        Graphic,
        on,
        array,
        Grid, Selection, Memory,
        Button,
        parser, declare
        parser.parse();
        var dataGrid = declare([Grid, Selection]);
        var columns = [{
          label: "",  //wasn't able to inject an HTML <div> with image here
          field: "ObjectID",
          formatter: makeZoomButton
          label: "Title",
          field: "title"
        grid = new dataGrid({
          bufferRows: Infinity,
          columns: columns
        }, "grid");
        var featureLayer;
        map = new Map("map", {
          basemap: "satellite",
          center: [-46.807, 32.553],
          zoom: 3
        //hide the popup if its outside the map's extent
        map.on("mouse-drag", function(evt) {
          if (map.infoWindow.isShowing) {
            var loc = map.infoWindow.getSelectedFeature().geometry;
            if (!map.extent.contains(loc)) {
              map.infoWindow.hide();
        //create a feature collection for the flickr photos
        var featureCollection = {
          "layerDefinition": null,
          "featureSet": {
            "features": [],
            "geometryType": "esriGeometryPoint"
        featureCollection.layerDefinition = {
          "geometryType": "esriGeometryPoint",
          "objectIdField": "ObjectID",
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "url": "images/flickr.png",
                "contentType": "image/png",
                "width": 15,
                "height": 15
          "fields": [{
            "name": "ObjectID",
            "alias": "ObjectID",
            "type": "esriFieldTypeOID"
            "name": "title",
            "alias": "Title",
            "type": "esriFieldTypeString"
        //define a popup template
        var popupTemplate = new PopupTemplate({
          title: "{title}",
          description: "{description}"
        //create a feature layer based on the feature collection
        featureLayer = new FeatureLayer(featureCollection, {
          infoTemplate: popupTemplate
        //associate the features with the popup on click
        featureLayer.on("click", function(evt) {
          map.infoWindow.setFeatures([evt.graphic]);
        map.on("layers-add-result", function(evt) {
          requestPhotos();
        //add the feature layer that contains the flickr photos to the map
        map.addLayers([featureLayer]);
      function requestPhotos() {
        //get geotagged photos from flickr
        //tags=flower&tagmode=all
        var requestHandle = esriRequest({
          url: "http://api.flickr.com/services/feeds/geo?&format=json",
          callbackParamName: "jsoncallback"
        requestHandle.then(requestSucceeded, requestFailed);
      function requestSucceeded(response, io) {
        //loop through the items and add to the feature layer
        var features = [];
        array.forEach(response.items, function(item) {
          var attr = {};
          attr["description"] = item.description;
          attr["title"] = item.title ? item.title : "Flickr Photo";
          var geometry = new Point(item);
          var graphic = new Graphic(geometry);
          graphic.setAttributes(attr);
          features.push(graphic);
        var items = array.map(features, function(feature) {
              return feature.attributes;
        var memStore = new Memory({
          data: items,
          idProperty: "ObjectID"
        window.grid.set("store", memStore);
        window.grid.set("sort", "ObjectID");
        grid.on(".field-ObjectID:click", function(e) {
          //retrieve the ObjectId when someone clicks on the magnifying glass
          if (e.target.alt) {
            zoomRow(e.target.alt);
        featureLayer.applyEdits(features, null, null);
      function requestFailed(error) {
        console.log('failed');
      function makeZoomButton(id) {
          var zBtn = "<div data-dojo-type='dijit/form/Button'><img src='images/zoom.png' alt='" + id + "'";
          zBtn = zBtn + " width='18' height='18'></div>";
          return zBtn;
      function zoomRow(id) {
        featureLayer.clearSelection();
        var query = new Query();
        query.objectIds = [id];
        featureLayer.selectFeatures(query, FeatureLayer.SELECTION_NEW, function(features) {
          //zoom to the selected feature
          var newExtent = features[0].geometry.getExtent().expand(5.0);
          map.setExtent(newExtent);
    </script>
  </head>
  <body class="claro">
    <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline'" style="width:100%; height:100%;">
      <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'" >
      </div>
      <div data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:275px">
      <div id="grid"></div>
     </div>
    </div>
  </body>
</html>
JakeSkinner
Hi Brian,
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #map {
        height:100%;
        width:100%;
        margin:0;
        padding:0;
      .esriScalebar{
        padding: 20px 20px;
      #map{
        padding:0;
      .dgrid-column-0 {
        width: 35px;
      .dgrid-row-odd {
      td div img:hover {
        cursor: pointer;
    </style>
    <script>
      var map, grid;
      require([
        "esri/map",
        "esri/request",
        "esri/tasks/query",
        "esri/graphic",
        "dojo/on",
        "dojo/_base/array",
        "dojo/domReady!"
      ], function(
        Map,
        FeatureLayer,
        PopupTemplate,
        esriRequest,
        Query,
        Point,
        Graphic,
        on,
        array,
        Button,
        parser, declare
        parser.parse();
        var columns = [{
          field: "ObjectID",
          label: "Title",
          field: "title"
          columns: columns
        }, "grid");
        var featureLayer;
          zoom: 3
          "featureSet": {
            "features": [],
          "drawingInfo": {
            "renderer": {
              "type": "simple",
              "symbol": {
                "type": "esriPMS",
                "width": 15,
                "height": 15
          "fields": [{
            "name": "ObjectID",
            "name": "title",
            "alias": "Title",
          title: "{title}",
          requestPhotos();
        var features = [];
          var attr = {};
          data: items,
          if (e.target.alt) {
          return zBtn;
    </script>
  </head>
      </div>
     </div>
    </div>
  </body>
</html>
BrianPaulson1
Jake,
Thank you so much for answering with the code.  You have made my day.  I am looking at this example:Zoom to Point using Show Find Task results in DataGrid Sample to try and figure out how to zoom to the feature(point) from the datagrid.  I am guessing I have to figure out the extent of the points.
KellyHutchins
Esri Notable Contributor
You could use centerAndZoom to zoom to the point. Here's an example based on Jake's code that shows this:
Flickr
Or you could use code like the example in this post   that will create an extent based on the point:
BrianPaulson1
Kelly,
Thank you.  You and Jake have been very helpful.  I now am displaying my data exactly as I wished.
MahtabAlam1
Jake,
You need to assign the Ids in requestSucceeded function something like :
var oid = 0;
          var attr = {};
   oid = oid + 1;
  attr["ObjectID"] = oid;
Other then that, please look at Kelly's reply for zoom to point feature.
