According to the W3C you can set a tabIndex for the following:
Modulo platform conventions, it is suggested that for the following elements, the tabindex focus flag be set:
If this is your only link on the page, you could use the a element and write:
document.getElementByTagName("a").tabIndex = -1;
to skip it.
If that does not work, you could try getting element by class name which in this case is actionList, so it would be:
document.getElementsByClassName("actionList").tabIndex = -1;
There may be a different way to write this if you are using AMD, but I am not sure.
Worst case scenario, you could host the JavaScript API locally and name then manually add tabIndex = -1.
