Problem with the Print Tool in Web AppBuilder
4655
01-23-2015 12:46 AM
TunaUnsal
I receive the error in the below image when I try to use the Print Widget in Web AppBuilder. Any advices on how to solve it?
TimWitt2
Hey Tuna,
did you setup a proxy?
Tim
TunaUnsal
Hi Tim,
Thank you for your response.
We do not have a proxy.
We were able to solve it by replacing the original test in the utility service with the below text:
https://gisportal.genelenergy.com:6443/arcgis/rest/services/Utilities/PrintingTools/GPServer/Export%20Web%20Map%20Task
The original text was:
https://GEANARCGISSDE01.GENELENERJI.LOCAL:7443/arcgis/sharing/tools/newPrint
It was just a try out so we will be pleased if you could tell the logic behind.
Many thanks,
Tuna
Tuna Unsal
Senior GIS Specialist
T
M
F
| +90.312.2188400
| +90.530.0404404
| +90.312.2191883
<http://www.genelenergy.com/>
www.genelenergy.com<http://www.genelenergy.com/>
