Merge / Append fatal script error - Please help
8604
11
01-21-2015 08:06 PM
DerekJones
Support failed to help with this today, have any of you resolved this lately?
I'm currently stuck trying to repair my Internet Explorer install as some of the potential fixes rely on it.
ArcGIS 10.2.1 : Advanced on Windows 7
Any help would be appreciated, this is too strange..
Also, here's as far as I can track it -- The file gets updated by ArcMap/Catalog it seems
KishorGhatage
Is it happening with other tools as well e.g. clip tool (analysis)?
Do you get the same error in ArcMap as well?
Have you tried disabling your anti virus system? (once I was observed this behavior. Especially with McAfee.)
1. Try Renaming ESRI folder, located in your profile.
C:\Users\User profile folder\AppData\Roaming\ESRI
2. Go to internet options > Security > Try setting security levels to Low  for all the zones
DerekJones
Did try both of those options, thanks
It happens in ArcMap too and primarily, testing in Catalog is just a bit quicker.
One per support's direction and the other as advised by links they'd sent
It does seem like Clip still works also
When last talking with support, we were stalled with me trying to repair an internet Explorer installation
TimothyHales
Esri Notable Contributor
DerekJones
Thank you
Had tried that fix.  Doesn't seem the right fit.
But, I'm in the process of 'fixing' my Internet Explorer install.
So, after that, I'll try a number of approaches again.
Regards,
Derek
KishorGhatage
1) Try removing the toolbox and adding it again from the 'System toolboxes'
2) Could you please ask your Colleague to log in your system and just the same behavior?
KishorGhatage
2) Could you please ask your Colleague to log in your system and just try reproducing the same behavior?
DerekJones
Solo operation
So, no can do, sorry
esri support had me have microsoft support fix my internet explorer
fast-forward, they reinstalled windows 7 and i'm currently reinstalling arcmap
so, no solution to be gleaned from this
i'm down to a complete blank slate
if an actual programming team ever properly diagnoses and resolves this issue,
they're encouraged to tell me, it would better amend my confidence in the product
as it is, with days lost, i probably have a day or less left to my license to finish this project work
DerekJones
also, about 1 year since I first downloaded arcmap and city engine
and now i'm pathetically lost trying to download my software and license on my own for a reinstall
it seems i need to request some permissions or something,
but if i'm just missing a location
please tell me
otherwise, i have to wait 4 hours to contact support
for another 2 hours of work to get back to where i started
i'll thank you all and remove these posts once i get through this all
apologies if i've rambled too much
Regards,
Derek
DerekJones
.. no weekend coverage ..
