arcgis javascript api map spatialreference changes when i add a layer
5210
01-21-2015 02:22 PM
davidzornosa
This one is strange: i have a map that takes features from a gp service and turns them into a graphics layer. If i add the layer, for some reason
the map's spatialreference changes from 4686 to 4326, if i comment that line, the change does not happen.
The features exposed by the service come in 4686, below is the relevant part, taken from the rest service page:
Even worse, the table where data is stored, was created via arccatalog with wkid 4686. So, i have absolutely no idea where this 4326 is coming from.
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
  <title>test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/dijit/themes/nihilo/nihilo.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.12/esri/css/esri.css">
  <script type="text/javascript">dojoConfig = {parseOnLoad: true};</script>
  <script src="http://js.arcgis.com/3.12/"></script>
  <script >
  var mapa;
  var gp;
  require([
  "esri/map",
  "dojo/parser",
  "esri/dijit/Print",
  "dijit/Toolbar",
  "dijit/form/Button",
  "dojo/dom",
  "dojo/dom-construct",
  "esri/layers/FeatureLayer",
  "esri/tasks/Geoprocessor",
  "esri/tasks/FeatureSet",
  "esri/layers/ArcGISTiledMapServiceLayer",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/tasks/query",
  "esri/tasks/QueryTask",
  "dojo/domReady!"
  function(Map, Extent, Button, Toolbar, parser, Print, FeatureLayer, Geoprocessor, Query, QueryTask) {
  mapa = new Map("map", {
  extent: new esri.geometry.Extent(-82.00, 4.50, -66.00, 14.00, new esri.SpatialReference({ wkid:4686 })),
  zoom: 8,
  slider: false,
  spatialReference: { wkid: 4686 }
  gp = new esri.tasks.Geoprocessor("...");
  gp.setOutputSpatialReference({wkid:4686});
  gp.submitJob({}, completeCallback, statusCallback);
  console.log(mapa);
  function completeCallback(jobInfo){
  gp.getResultData(jobInfo.jobId, "...", function(results, messages) {
  var symbol_ = new esri.symbol.SimpleMarkerSymbol(esri.symbol.SimpleMarkerSymbol.STYLE_SQUARE, 10, esri.symbol.SimpleLineSymbol.STYLE_SOLID, new esri.Color([255,0,0]) );
  var gl = new esri.layers.GraphicsLayer();
  for (var i = 0; i < results.value.features.length; i++) {
  if (results.value.features.geometry != null) {
  results.value.features.setSymbol(symbol_);
  console.log(results.value.features);
  gl.add(results.value.features);
  mapa.addLayer(gl); // <-- THIS IS THE PROBLEMATIC LINE
  console.log(gl);
  function statusCallback(jobInfo) {
  </script>
</head>
<body>
<div id="map"></div>
</body>
</html>
Thanks a lot.
Tags (1)
