javascript api 3.11 query task error " undefined is not a function"
5887
01-14-2015 08:07 AM
RupaliKiran
Can someone please help me with the code below.
I have been struggling to find why I am getting "Uncaught TypeError: undefined is not a function" error
at   QueryTask.execute(Qry,showResults);
    <script>
      require([
        "esri/map",
  "esri/layers/ArcGISDynamicMapServiceLayer",
  "esri/dijit/BasemapToggle",
        "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleFillSymbol",
        "esri/Color",
        "dojo/on",
        "dojo/dom",
  "dijit/registry",
        "dojo/_base/array",
        "dojo/_base/connect",
        "dojox/grid/DataGrid",
        "dojo/data/ItemFileReadStore",
        "dijit/form/Button",
        "dojo/parser",
  "dijit/form/ComboBox",
  "dojo/store/Memory",
        "dijit/form/FilteringSelect",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dojo/domReady!",
  "esri/tasks/query", "esri/tasks/QueryTask"
   ], function(
  Map, ArcGISDynamicMapServiceLayer, BasemapToggle, FindTask, FindParameters, SimpleMarkerSymbol, SimpleLineSymbol, SimpleFillSymbol,
  Color, on, dom, registry, arrayUtils, connect, DataGrid, ItemFileReadStore, Button, parser, Memory, FilteringSelect, ComboBox, Query, QueryTask
  var findTask, findParams;
  var Query, QueryTask;
  var map, center, zoom;
  var infoTemplate;
  var grid, store;
  parser.parse();
  esri.config.defaults.io.proxyUrl = "http://agstest.prod.loudoun.local/Loudoun/ProxyPage/proxy.ashx";
  infoTemplate = new esri.InfoTemplate(
  "${PA_MCPI}",
  "Available Acres: ${MKTG_AVL_A}<br />Zone: ${ZO_ZONE}<br />Company: ${MKTG_Contact}<br />Contact: ${MKTG_CON_FN} ${MKTG_CON_LN} <br />   ${MKTG_CON_St}    ${MKTG_CON_city} ${MKTG_CON_State} ${MKTG_CON_zip}<br />   ${MKTG_CON_ph}<br />   ${MKTG_CON_email}");
  registry.byId("search").on("click", doFind);
  registry.byId("search1").on("click", doFind1);
  registry.byId("searchQry").on("click", QryExe);
  center = [-77.4875, 39.0436];
  zoom = 11;
  map = new esri.Map("map", {
        basemap: "topo",
        center: center,
        zoom: zoom
   //infoWindow: infoWindow
  var toggle = new BasemapToggle({map: map,
        basemap: "satellite"}, "BasemapToggle");
        toggle.startup();
  QueryTask = new QueryTask("http://agstest................................./MapServer/0");
        //Create Find Task using the URL of the map service to search
  findTask = new FindTask("http://agstest........................./MapServer");
  // add dynamic map service layer
        var urlDyn = "http://agste................................./MapServer";
        var usaLayer = new ArcGISDynamicMapServiceLayer(urlDyn, {
          opacity: 0.45,
          visible: true
        //usaLayer.setVisibleLayers([2]);
        map.addLayer(usaLayer);
        map.on("load", function () {
  Qry = new Query();
  Qry.returnGeometry = true
  Qry.outFields = ["MKTG_TOTAL", "ZO_ZONE"];
  //Create the find parameters
          findParams = new FindParameters();
          findParams.returnGeometry = true;
          findParams.layerIds = [1];
          findParams.searchFields = ["ZO_ZONE", "MKTG_CON_1"];
          findParams.outSpatialReference = map.spatialReference;
          console.log("find sr: ", findParams.outSpatialReference);
        function doFind() {
           //map.infoWindow.hide();
            dom.byId("owner").value = dom.byId("owner").defaultValue;
          //Set the search text to the value in the box
          findParams.searchText = dom.byId("ZoneTyp").value;
          findTask.execute(findParams, showResults);
  function doFind1() {
       dom.byId("ZoneTyp").value = dom.byId("ZoneTyp").defaultValue;
          findParams.searchText = dom.byId("owner").value;
  function QryExe() { //getting error on this function....)
       // var val = dom.byId("acres").value;
        //alert(val);
        Qry.where =  "ZO_ZONE LIKE 'PDOP'";
        //Query.where = "ZO_ZONE LIKE '%" +  dojo.byId('acres').value + "%'";
        function showResults(results) {
          //This function works with an array of FindResult that the task returns
   map.graphics.clear();
          var symbol = new SimpleFillSymbol(
            SimpleFillSymbol.STYLE_VERTICAL,
            new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([0, 102, 204]), 3),
            new Color([0, 102, 204, 0.5])
          //create array of attributes
          var items = arrayUtils.map(results, function (result) {
            var graphic = result.feature;
            graphic.setSymbol(symbol);
  graphic.setInfoTemplate(infoTemplate);
            map.graphics.add(graphic);
            return result.feature.attributes;
          //Create data object to be used in store
          var data = {
            identifier : "PA_MCPI", //This field needs to have unique values
            label : "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
            items : items
          //Create data store and bind to grid.
          store = new ItemFileReadStore({data : data});
          var grid = registry.byId("grid");
          grid.setStore(store);
          grid.on("rowclick", onRowClickHandler);
          //Zoom back to the initial map extent
          map.centerAndZoom(center, zoom);
        //Zoom to the parcel when the user clicks a row
        function onRowClickHandler(evt) {
          var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).PA_MCPI;
          var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
    return ((graphic.attributes) && graphic.attributes.PA_MCPI === clickedTaxLotId);
     //------------------------test-----------------
   map.infoWindow.setContent(graphic.getContent());
          map.infoWindow.setTitle(graphic.getTitle());
          map.infoWindow.show(evt.screenPoint,map.getInfoWindowAnchor(evt.screenPoint));
          if ( selectedTaxLot.length ) {
            map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
  </script>
KenBuja
MVP Esteemed Contributor
The first thing I see is your function aliases don't match your require modules. These have to be in the correct order.
  "dojo/parser",
  "esri/tasks/query",
  "esri/tasks/QueryTask",
  "dojo/domReady!"
KenBuja
  "dojo/parser",
  "esri/tasks/query",
  "dojo/domReady!"
RupaliKiran
TThanks Ken! Will fix the order and test.
RupaliKiran
Thanks! that was it!! Appreciate your help
