Creating Field Calculator Expression
5981
6
01-13-2015 01:06 AM
WahajHabib
Hi, I want to project population from an old census report.....the formula is as follows
   population*(1+(growth rate/100))^16
I am trying this expression for calculating from attribute table but ITS NOT WORKING
  [POP_B_SEX]*(1+ (4.33 / 100 ))Exp (16 )
Note : [POP_B_SEX] is the only column i am using from attribute table.
Pieter_Geertvan_den_Beukel
The formula works for me....
Go in ArcMap to the Geoprocessing menu and click Geoprocessing Results. What is the error message that the Field Calculator returns?
To make the formula more simple:
(1+ (4.33 / 100 ))^16 = 1.97037
Your formula can be rewritten as:
[POP_B_SEX]*1.97037
DanPatterson_Retired
Exponents aren't ^, they are **
WahajHabib
Yes but you see in the expression i am using "exp()"...wont they work?? and i tried with ** and doesn't work either....i guess there is something wrong with the expression....
Exp(16) means e^16 = 2.718282^16 = 8886111
You can simply use the ^ sign as in the formula.
Note: there is a difference between:
[POP_B_SEX]*(1+ (4.33 / 100 ))^16
and
([POP_B_SEX]*(1+ (4.33 / 100 )))^16
WahajHabib
Yeah i tried with ^ already but it doesn't work
[POP_B_SEX]*1.97037
WahajHabib
Yes it worked i had an extra square bracket..thanks
