Hello everybody I need some help about python scripting to create a square buffer around points feature class ?
12811
9
01-12-2015 06:21 PM
MahmoudMdookh
If there is a problem by giving me the script , I just need some explanation about how can I start scripting the square buffer?
I'm a beginner python programmer, I'm looking forward to be professional in python , and I hope that any one will help me !
Thanks in advance...
XanderBakker
Esri Esteemed Contributor
... and if you want to create an output that contains the attributes of the input, you can try this:
import arcpy, os
def main():
    # inputs
    fc_in = r'D:\Xander\EPM\Datos pruebas\gdb\datos erase.gdb\points03'
    width = 0.005 # with of the output rectangle
    height = 0.005 # height of the output rectangle
    # output
    fc_out = r'D:\Xander\EPM\Datos pruebas\gdb\datos erase.gdb\rectangles3'
    # create empty output featureclass
    sr = arcpy.Describe(fc_in).spatialReference
    out_ws, out_name = os.path.split(fc_out)
    arcpy.CreateFeatureclass_management(out_ws, out_name, "POLYGON", fc_in, "DISABLED", "DISABLED", sr)
    # make fields list
    flds_use = correctFieldList(arcpy.ListFields(fc_in))
    # create insert cursor
    with arcpy.da.InsertCursor(fc_out, flds_use) as curs_out:
        # loop through input features
        with arcpy.da.SearchCursor(fc_in, flds_use) as curs_in:
            for row_in in curs_in:
                polygon = createRectangleFromPoint(row_in[0].firstPoint, width, height, sr)
                row_out = buildRow(row_in, flds_use, polygon)
                curs_out.insertRow(row_out)
def createRectangleFromPoint(pnt, width, height, sr):
    arrPnts = arcpy.Array()
    pnt2 = arcpy.Point(pnt.X - width, pnt.Y - height)
    arrPnts.add(pnt2)
    pnt2 = arcpy.Point(pnt.X - width, pnt.Y + height)
    arrPnts.add(pnt2)
    pnt2 = arcpy.Point(pnt.X + width, pnt.Y + height)
    arrPnts.add(pnt2)
    pnt2 = arcpy.Point(pnt.X + width, pnt.Y - height)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    return arcpy.Polygon(arrPnts, sr)
def correctFieldList(flds):
    flds_use = ['Shape@']
    fldtypes_not = ['Geometry', 'Guid', 'OID']
    for fld in flds:
        if not fld.type in fldtypes_not:
            flds_use.append(fld.name)
    return flds_use
def buildRow(row_in, flds_use, polygon):
    try:
        lst_in = list(row_in)
        lst_in[0] = polygon
        return tuple(lst_in)
    except Exception, e:
        print("buildRow exception: {0}".format(e))
        return None
if __name__ == '__main__':
    main()
DanPatterson_Retired
See Xander Bakker's diamond buffer script...a little bit of fiddling and you can turn a diamond into a square
Venkata_RaoTammineni
XanderBakker
Below the code based on the thread mentioned by Dan Patterson‌ adapted to create squares or rectangles. Change lines 6 and 11 to point to your input and output (will be created) and change the sizes on lines 7 and 8. For some more snippets with Python have a look at: https://community.esri.com/docs/DOC-1927
import arcpy
def main():
    # inputs
    fc = r'D:\Xander\Rectangles\data.gdb\points'
    # output
    fcout = r'D:\Xander\Rectangles\data.gdb\rectangles'
    sr = arcpy.Describe(fc).spatialReference
    features = []
    with arcpy.da.SearchCursor(fc, ("SHAPE@")) as cursor:
        for row in cursor:
            rectangle = createRectangleFromPoint(row[0].firstPoint, width, height, sr)
            features.append(rectangle)
    # write to output
    arcpy.CopyFeatures_management(features, fcout)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    main()
XanderBakker
import arcpy, os
def main():
    # inputs
    # output
    # make fields list
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    arrPnts.add(pnt2)
    for fld in flds:
    return flds_use
    try:
        lst_in[0] = polygon
        return None
    main()
AndrewL
Is it possible to use this code using a width and height attribute field in the input file for different widths and heights? Thank you.
I tried the following but get an error: pnt2 = arcpy.Point(pnt.X - width, pnt.Y - height)
TypeError: unsupported operand type(s) for -: 'float' and 'str'
width = "float(!newWidth!)"
height = "float(!newHeight!)"
XanderBakker
Hi Andrew Louchios ,
You cannot define the width like you did and as you can notice in the error you cannot mix numeric and text values. You will probably have to do something like this:
    fld_width = "name of your width field"
    fld_height = "name of your height field"
    with arcpy.da.SearchCursor(fc_in, (flds_use, fld_width, fld_height)) as curs_in:
            width = row_in[1]
            height = row_in[2]
In the beginning you will have to define the names of your width and height field and in the search cursor you will have to include the field names in the list of fields. Inside the loop you will have to read the values and use them in the CreateRectangleFromPoint function.
AndrewL
Thanks for your help! I used "width" twice because I am just creating squares.
AndrewL
After running this code I believe the "width" and "height" values are actually half of the width and half of the height of the output rectangle. In other words width and height are radii values.
XanderBakker
Hi louchios ,
That is a correct observation although it would be better to avoid confusion to maintain your width and height values and correct the code to use width/2 and height/2 in creating the corner points.
