Customizing attribute inspector UI arcGIS javascript api
4233
01-09-2015 09:40 AM
ushaganta
In attribute inspector after  setting the height scrolling is coming and i need to fix save,delete buttons and set scrolling to the fields section.
AkshayHarshe
Hi Usha,
If you are using
Using the attribute inspector | ArcGIS API for JavaScript  sample from the api and you are not able to get rid of the scroll bar use the following code in your css.
.esriPopup .contentPane {
  height: 180px;
If you want to construct a div on infowindow see if dom-construct can help
dojo/dom-construct — The Dojo Toolkit - Reference Guide
Akshay Harshe
Akshay Harshe
