Minimum Z Value Location on a Polyline
3799
01-08-2015 12:09 PM
JayHalligan
Does anyone know how to find the minimum z value *location* on a polyline?  Essentially I need to create a point feature of the minimum z value location.
DarrenWiens2
Using arcpy, you can loop through each vertex (Points) on each Polyline. Points store the Z coordinates. Once you determine the minimum Z coordinate for each line, create a new point at the corresponding X, Y location. You will likely find the articles on Reading and Writing Geometries helpful.
