Proxy.ashx Basic Authentication
8529
01-07-2015 02:49 AM
KarthikBalachandran
We have downloaded the proxy.ashx files to interface with ArcGIS services.
Our setup is
Javascript -> Proxy Handler -> ArcGIS services.
The proxy code works well in Token based authentication.
We updated the proxy.ashx code to enable Basic Authentication.
The proxy returns the response to the client as expected
But the Base Map does not get loaded.
Below is the code
function init() {
    esriConfig.defaults.io.proxyUrl = proxyURL
    esriConfig.defaults.io.alwaysUseProxy = true;
function LoadMap() {
    init();
    var evt, XY;
      var  layer = new esri.layers.ArcGISDynamicMapServiceLayer(Basemap URL);
       wkidref = wkid;
    //initialze the map control
    map = new esri.Map("map");
    map.addLayer(layer);
    map.on("load", function () { map.extent = layer.fullExtent });
We inspected the layer value and the proxy was returning the json as expected.
The load of the base map does not seem to happen on load function call. We noticed that the call to export the image does not take place on load
Can anyone assist on this issue?
