Hover over to work on multiple feature layers
6034
01-06-2015 12:02 PM
JssrRR
I  have three feature layers in this application and I have a tooltip dialog working on the first layer that I added. I want to know if there is way, with which I can have the tooltip, hover over dialog box, to show up on other two layers as well. I want only the nursing facilities to be selected, within the buffer, when clicked on any feature. If I have the tooltip working on other layers, then I can identify the center of the circle to draw a buffer and select nursing facilities.
Here is the JSfiddle I am working on:
http://jsfiddle.net/JSSR/kLasn1cc/
Thanks!
RobertScheitlin__GISP
Saloni,
   So unless I am not understanding the issue then it is as simple as adding a mouse over event function to the other two layers.
I also removed the line where you were showing the map.infowidow for some reason and never using it.
Your code updated
Saloni,
   What field are you wanting to use in those other layers? Neither of those layers have an outfields configured...
JssrRR
Robert,
Sorry, in  featureLayer 1, I want the to name of the urban place to show up like this  " Name: ${NAMELSAD}" and in featureLayer 2, I want to  show the Zipcode which is in field "ZipCode:  ${GEOID}". I already have Nursing facility showing the facility ID.
Thanks.
Saloni,
Your code updated
JssrRR
Robert,
This is exactly what I was looking for, the examples that I had come across so far had only one layer, and I did not think it would be so simple, still learning new to this, thanks for your help!
