Execute code with a timer
4804
01-05-2015 09:55 AM
RusselKlueg
Hello All,
I have written a code to download some data, run a few operations, symbolize it, and export it but I need this code to run on a timer. IE execute itself every 15 minutes.
My issue is that I can not figure out how to write the script so that it will execute the file every fifteen minutes. Once it's written I plan having it run on startup so that if the computer is up it will update my files for the operations center. Any advice would be greatly appreciated!
Tags (3)
AnthonyGiles
Honored Contributor
Russel,
If your code is just a python file (.py) you can just set up a windows scheduled task to run it:
Scheduling a task - Windows Help
AnthonyGiles
Honored Contributor
Russel,
