Error after updating to Javascript 3.12
3849
5
12-22-2014 09:44 AM
by Anonymous User
Not applicable
I updated my app to 3.12 and am getting the following error:
Uncaught TypeError: Cannot read property 'toString' of undefined
It is being triggered by the following line:
init.js:899
function(c,a,d){c=k.getObject(a,!1,g);d&&(c=k.getObject(d,!1,b).call(b,c,a));return e(c,a).toString()}
Any ideas? It was working fine in 3.11. Thanks
KellyHutchins
Esri Notable Contributor
Without seeing a code example that shows the problem its hard to say what is causing your app to fail after migrating to 3.12. Do you have a test case that shows the problem?
HeikoHeijenga
The code snippet you supplied is from dojo/string.substitute. Can you supply the entire stack trace when this error occured?
by Anonymous User
Not applicable
It is hard to send a code sample since this error occurs onload.  Here is the stack trace from the error as well as the code for which is being called out (coords.js)
require([
  "dojo/dom",
  "dojo/on",
  "dijit/Menu",
  "dijit/MenuItem",
  "dijit/MenuSeparator",
  "dijit/layout/ContentPane",
  "dojo/number",
  "esri/geometry/Point",
  "esri/geometry/webMercatorUtils",
        "dojo/domReady!"
    ], function(dom, on, Menu, MenuItem, MenuSeparator, ContentPane, number, Point, webMercatorUtils) {
  var currentLocation;
  //Right Click Menu
  var coordMenu = new Menu({
  targetNodeIds: ["map"],
  onOpen: function(box) {
  currentLocation = getMapPointFromMenuPosition(box);
  var coords = webMercatorUtils.webMercatorToGeographic(currentLocation);
  var latitude = number.format(coords.y, {places:6, type: "decimal"});
  var longitude = number.format(coords.x, {places:6, type: "decimal"});
  dom.byId("coordsDisplay").innerHTML = "<div id=\"coordsSelect\">" + latitude + ", " + longitude + "</div>";
  coordMenu.addChild(new ContentPane({
  content:"<div id=\"coordsDisplay\"></div>"
  coordMenu.addChild(new MenuItem({
            label: "Close",
  iconClass: "dijitIconDelete"
  coordMenu.startup();
  function getMapPointFromMenuPosition(box) {
  var x = box.x, y = box.y;
  switch( box.corner ) {
  case "TR":
  x += box.w;
  break;
  case "BL":
  y += box.h;
  break;
  case "BR":
  x += box.w;
  y += box.h;
  break;
  var screenPoint = new Point(x - map.position.x, y - map.position.y);
  return map.toMap(screenPoint);
YungKaiChin
Mostly likely a timing issue.
Does your app still run properly?
by Anonymous User
Not applicable
Yeah I figured its a timing issue when the app is parsed.  It does not run when updated to 3.12, still troubleshooting.
