Arcgis.com pop up not displaying value
3465
12-19-2014 06:34 AM
LisaHuggins
I have this problem with a web map that is published and some pop ups work fine and some do not.  In this case, I have pipes labeled with diameter and this is working well.  The diameter displays.  However, when I click on the pipe to see the pop up, it appears that the diameter field is empty.  I have some other pipe layers in the map that work fine.  It seems my fields that end in an underscore are having issues but others are not.  Could there be something to that or am I on the wrong track?
In the attached example, PipeSize_ is used to generate 8" labe in the map.  Pop up shows that it is empty.
Message was edited by: Lisa Huggins
