Double Quote in Label Expression
11355
20
12-18-2014 07:00 AM
mneer
Trying to get my label expression to work here.  The problem is some of my table
records have a double quote in it (" symbol).  I want to rename as such see example below:
(30" PVC Pipe Drain)  and rename it to (30 inch)
I use the following vbScript - but get nowhere:
Function FindLabel ( [NAME] )
If Not IsNull([NAME]) Then
NewStr = Replace([NAME], "30'' PVC Pipe Drain", "30 inch")
  FindLabel = NewStr
End If
End Function
  --- also I tried python and get nowhere:
def FindLabel ( [NAME] 😞
  S = [NAME]
  S = S.replace( '30'' Drain, Vitreous Clay Pipe', '30 in')
  return S
TedKowal
Honored Contributor
Using VBScript....
Replace( [Name],chr(34)," inch")
No advance script or block needed.  --- Tested it with null values no issues..... if you simply want to replace " --> inch
Re reading you question If you want to shorten your label then you would need an advanced expression:
Function FindLabel ( [Name]   )
dblQuote = instr( [Name] ,chr(34))
if dblQuote > 0 then
   newStr = left( [Name] ,dblQuote - 1) & " inch"
else
   newStr = [Name]
end if
  FindLabel = newStr
End Function
Miguel_AngelBarrientos_Martíne
Hi:
Can you replace temporary the " for another sign for example ºº and then replace again?
mneer
no
JamesFitzgerald
Hello M. Neer,
As a quick fix, you could export the attribute table to a databasefile.dbf and work on it from a standalone table to remove the quotation ("). then you could bring it back into arcGIS and join it to your shapefile.shp. Not as quick as code but it works!
James
mneer
Yes, that is a valid idea but I had forgotten to mention
earlier that
this is a source feature  from our enterprise and I don't wish to
copy or manipulate the data in any way.   My
intention is to re-label
on the fly dynamically.
Copying the data and pointing to copied source
is what I am attempting to avoid here.
JamesFitzgerald
Hey,
Replace 'St' or 'St.' starting a new word at the end of the string with the word 'Street'.
Expression: update_street(!ADDRESS!)
Expression Type: PYTHON_9.3
Code Block:
import re
def update_street(street_name):
     return re.sub(r"""\b(St|St.)\Z""",
               'Street', street_name)
Check ArcGIS Desktop under Regular Expressions.
mneer
So, I attempted to reference my first posting above as an example (30" PVC Pipe Drain),  in correlation with your posted py parser and it didn't appear to do anything.
Of course I may not be applying it correctly? It runs but does not change anything at this point.
import re
def FindLabel([NAME]):
     return re.sub(r"""\b(30'' PVC Pipe Drain|30''Drain.)\Z""",
               '30 in', [NAME])
Other helpful info maybe?  Field Name = [NAME] and the text string in question  30'' PVC Pipe Drain
TedKowal
Honored Contributor
Using VBScript....
else
   newStr = [Name]
end if
  FindLabel = newStr
End Function
mneer
Excellent !   So very close.  Need to drop all the text AFTER the word inch.  When I attempt to
use LEFT() it reverts back to " double quote so I know we are close here.
NewStr = Replace([Name],chr(34)," inch")
  FindLabel = NewStr
End If
End Function
Was (30" PVC Pipe Drain) and now is (30 inch PVC Pipe Drain30" PVC Pipe Drain) just need to drop text
PVC Pipe Drain.   Perhaps compound it with LEFT()?
RichardFairhurst
You should have included that detail in your description of what you were trying to do, since dropping text is a completely different issue.  So Try:
    NewStr = [Name]
    If Instr(NewStr, chr(34)) > 0 Then
      NewStr = Left(NewStr, Instr(NewStr, chr(34)))
    End If
    NewStr = Replace(NewStr, chr(34), " inch")
    FindLabel = NewStr
  End If
End Function
