Double Quote in Label Expression
11353
20
12-18-2014 07:00 AM
mneer
Trying to get my label expression to work here.  The problem is some of my table
records have a double quote in it (" symbol).  I want to rename as such see example below:
(30" PVC Pipe Drain)  and rename it to (30 inch)
I use the following vbScript - but get nowhere:
Function FindLabel ( [NAME] )
If Not IsNull([NAME]) Then
NewStr = Replace([NAME], "30'' PVC Pipe Drain", "30 inch")
  FindLabel = NewStr
End If
End Function
  --- also I tried python and get nowhere:
def FindLabel ( [NAME] 😞
  S = [NAME]
  S = S.replace( '30'' Drain, Vitreous Clay Pipe', '30 in')
  return S
JamesFitzgerald
Thanks! The code you all provided is very useful. I understand, and this will be very useful when I cannot not change the attributes to label.
James
