Map & query results are not show up when using browsers like IE & Firefox
4913
7
12-19-2014 09:37 AM
MayJeff
Hell all,
I can't figure out why the map & query results won't display when using Firefix and IE.  Only able to use it in Chrome?
Does anyone got this problem too?
Here is my jsfiddle:
Edit fiddle - JSFiddle
Thank you.
HeikoHeijenga
You're not using sort correctly, needs to be something like:
        var sortedFeatures = results.features.sort(function(a,b) {
                return a.attributes.PARCELID.localeCompare(b.attributes.PARCELID);
RobertScheitlin__GISP
May Jeff,
    Other browsers do not support the Array.prototype.sort (the way that you are trying to use it).
Here is the workaround for your code.
var sortedFeatures = results.features;//.sort('PARCELID');
look at using the Query orderByFields
Query | API Reference | ArcGIS API for JavaScript
HeikoHeijenga
Robert, all browsers support Array.sort...
True, but not the way he was using it. Only Chrome did not have issue with his use of it. I will edit my response.
HeikoHeijenga
May Jeff,
   This link may help as well.
Array.prototype.sort() - JavaScript | MDN
MayJeff
Thank you for taking your times to look into it.  I updated the sorting part based on Heiko.  Edit fiddle - JSFiddle  and I also do another way for sorting based on Robert help link mentioned on his last posted Edit fiddle - JSFiddle
When I use notepadd ++ to create a file and run it on IE -  always got Access Denied - See my attachment file.
Both links above using JSFiddle can see both map and query results when using IE but not firefox.
Using firefox so far nothing show up at all.  Got any ideas?
Thank you.
