No fields in result map service of raster layer
2984
12-18-2014 10:14 AM
JoshObrecht
I am showing a raster layer as a result map service to be used in the Javascript API. The raster layer that is produced has multiple fields. However, the result map service shows no fields. Is this a limitation of using a raster layer as the result map service or is there something else going on?
DanielStauning
Hi Josh,
An image service may be required to expose the raster attribute table resource, I don't believe this resource is available through map services:
ArcGIS REST API
Here's a sample image service with the raster attribute table resource exposed that you can test with:
NLCDLandCover2001 (ImageServer)
Does this answer your question?
-Dan
JoshObrecht
Are you able to have the result service be an image service?
DanielStauning
Josh,
Are you referring to a result map service of a geoprocessing service output? My understanding is that a map service is the only supported result service type. You may just be running into a limitation here, sorry I can't be of more help.
ArcGIS Help (10.2, 10.2.1, and 10.2.2)
-Dan
JoshObrecht
Yes I am referring to a result map service. Well that's not good.
