ArcGIS Server MapService Query
3126
12-18-2014 10:47 AM
ShaningYu
Honored Contributor
I might classify this thread as a bug report.  The scenario is described below:
I created a JS application that does query on a MapService layer.  In the debugging, I got the value of the query.where  clause.  If I post this clause into the MapService layer's Where textbox, and then click the Query button, I can get respected results (e.g. a couple of dozens of records, which are the same as that in ArcMap's definition-query on the map layer in the map document).  This query clause is VERY long.  In my JS application,  I put a break-point in function showResults().  If the query clause is NOT too long, the code goes through smoothly.  However, if the clause is Too Long, it goes through without any break.  I would guess there is may be a bug in the API that may limits the length of whereClause.  If you have similar experience like that, please share  Thanks for your attention.
queryTask.execute(query, showResults);
function showResults(result) {
    var items = [];
    for (var i = 0, il = result.features.length; i < il; i++) {
         items.push(result.features.attributes);
Tags (1)
KenBuja
MVP Esteemed Contributor
If your request is longer than 2048 characters, you'll need to use a proxy.
ShaningYu
Honored Contributor
Ken:  Thanks for your point.  I added a couple lines of code, but it still does not work.  The code I added are listed below:
  dojo.require("esri.urlUtils");   // for proxy
In function init(), added:
  esriConfig.defaults.io.proxyUrl = _proxyURL;
  esriConfig.defaults.io.alwaysUseProxy = false;
Did I miss anything else?  Thanks if you can further point it out.
