Problem in Creating Envelope Polygon using Python
8030
12-14-2014 10:43 AM
AhsanAbbas
I need a script that makes an envelope polygon feature class for the Hawaii.shp (Multi-part polygon) feature class. There is actually a tool that accomplishes this called Minimum Bounding Geometry. But i have to do it using python script which directly deals with the geometry properties. how can i do it, i have tried it without using any geometry property, but facing problem doing it though Geometry , Shape file is attached.
env.workspace = r"D:\Python Exercise\Exercise08-2014-12-05\Exercise08"
inFeatures = "Hawaii.shp"
outFeatureClass = "Hawaii_Profile.shp"
arcpy.MinimumBoundingGeometry_management(inFeatures, outFeatureClass, "ENVELOPE", "NONE")
Tags (3)
DarrenWiens2
At the risk of doing your homework for you (you're only hurting yourself, but I figure the assignment must be in by now), here's the answer:
>>> with arcpy.da.SearchCursor("Hawaii","SHAPE@") as cursor:
...    for row in cursor:
...        print row[0].extent
...        polygon = [arcpy.Polygon(arcpy.Array([arcpy.Point(row[0].extent.XMin,row[0].extent.YMin),arcpy.Point(row[0].extent.XMax, row[0].extent.YMin),arcpy.Point(row[0].extent.XMax,row[0].extent.YMax),arcpy.Point(row[0].extent.XMin,row[0].extent.YMax)]))]
372236.642923135 2094769.12137791 941120.12366655 2458884.21017432 NaN NaN NaN NaN
>>> arcpy.CopyFeatures_management(polygon,'in_memory\extent')
<Result 'in_memory\\extent'>
DanPatterson_Retired
I will refer you to arcpy's Polygon class for the required inputs.... extent .... should provide the clues
AndrewChapkowski
Do you need the extent of every geometry? or the whole feature class?
AhsanAbbas
whole feature class
DarrenWiens2
