Problems adding attributes to a graphic
3499
12-12-2014 06:47 AM
TracySchloss
Honored Contributor
I am buffering points and I want to put the attributes of original point on the resultant buffer polygon.  I also want to add an extra attribute for 'source' to indicate which layer I was buffering.
The graphic is getting the feature.attributes from the original point.  I thought I could use graphic.attr('name','value') to add the extra attribute I want.  It doesn't seem to be doing anything.  It's not generating any error either.  Is this not the proper method?
//create a buffer graphic for every point
function generateBufferGraphic(features){
    bufferLayer.clear();
  var radius = registry.byId("bufferSelect").value;//user can select buffer distance
  var idPoint,circle;
  arrayUtils.forEach(features, function (feature){
    idPoint = feature.geometry;
     circle = new Circle({
        center: idPoint,
        geodesic: true,
        radius: radius,
        radiusUnit: "esriMiles"
      var graphic = new Graphic(circle, bufferSymbol,feature.attributes);
      graphic.attr('source','layername');
      bufferLayer.add(graphic);
Tags (1)
KenBuja
MVP Esteemed Contributor
You have to set the attributes of a graphic with this syntax
//is layername a string or a variable in your code? This assumes it a variable
graphic.attributes.source = layername
KenBuja
TracySchloss
Honored Contributor
That works, thanks.  I'm not sure what the documentation means for the syntax I was trying.
KenBuja
I ran into the same issue, which is how I got this answer. I agree that the documentation needs to be clarified.
