There are a few ways to accomplish this. Option one would be to create a new group in ArcGIS Online that contains the basemaps you want to display then use that to set the BasemapGallery basemapGroup constructor option.
var basemapGallery = new BasemapGallery({
showArcGISBasemaps: true,
basemapsGroup: { owner: "esri", title: "Community Basemaps" },
map: map
Another alternative is to use the BasemapGallery load event to remove the maps you do not want from the gallery. In this code snippet we remove the basemap with a title of Imagery from the gallery. However you might run into issues with this approach if your web application will be used by multiple locales. For example if your site were viewed in a browser with a French locale the Imagery basemap would not be removed because its title is not Imagery it would be the French equivalent.
map: map
}, "basemapGallery");
basemapGallery.on("load", function(){
for(var i=0; i < basemapGallery.basemaps.length; i++){
if(basemapGallery.basemaps.title === "Imagery"){
basemapGallery.remove(basemapGallery.basemaps.id);
basemapGallery.startup();
