JavaScript - TOC layers callapse & expand
2364
12-12-2014 08:02 AM
ShaningYu
Honored Contributor
From the example: http://gmaps-utility-gis.googlecode.com/svn/tags/agsjs/latest/examples/toc.html ,
I added
    autoToggle: false  //whether to automatically collapse when turned off, and expand when turn on for groups layers. default true.
in the TOC layer's code.  However, in my application, this function does work.
Besides, how to set the layer as checked-off initially in the TOC?
Thanks if you can help.
Tags (1)
KenBuja
MVP Esteemed Contributor
To have a layer show up as collapsed in the TOC, set its visibility to false once its loaded. Here's an example
layerDynamic = new ArcGISDynamicMapServiceLayer(yourURL, {
layerDynamic.on("load", function () { layerDynamic.setVisibility(false); })
KenBuja
ShaningYu
Honored Contributor
Thanks a lot.
KenBuja
Of course, it's easier to just the layer's visibility to false when you create it. I should have suggested that first...
    visible: false
ShaningYu
Honored Contributor
Thanks a lot.
