Here is the code for the Location, I have tried this on an Ipad 2 and also an Air 2 with the same Results-publishing to Android works fine though .... Save there is no Compass support on Android.
I have removed the specific server as were not to make the Services Public Quite yet, Also Removing the s out of HTTPS: works?? the services have had the token removed and seem to work fine just using http? This is odd because in the other runtimes this will not work (iOS, Android and .Net)... hmmmm
Thanks for the speedy response back
import QtQuick 2.1
import QtQuick.Controls 1.0
import QtQuick.Dialogs 1.2
import QtQuick.Window 2.0
import QtQuick.Layouts 1.1
import ArcGIS.Runtime 10.3
import ArcGIS.Runtime.Toolkit.Dialogs 1.0
import QtPositioning 5.3
import QtSensors 5.3
ApplicationWindow {
width: 320
height: 480
title: "WrmsLite"
Rectangle{
anchors.fill: parent
property int hitFeatureId:0
property variant attrValue
property real scaleFactor: 1
property bool settingsView: true
states:[
State{
when:settingsDisplay
changes:[
PropertyChanges {
target: settingsDisplay
anchors.fill:parent},
PropertyChanges{
target:mainMap
visible:false}
Rectangle{
color:"white"
GeodatabaseFeatureServiceTable{
url:"https://SERVER/arcgis/rest/services/WRMS/Incidents/MapServer/0"
Map{
property Point locationPoint: Point{
property bool valid: false
spatialReference: SpatialReference{
wkid: 4326
ArcGISTiledMapServiceLayer{
url:"http://Server/arcgis/rest/services/USA_Topo_Maps/MapServer"
ArcGISDynamicMapServiceLayer{
url:"https://Server/arcgis/rest/services/WebMercator/PublicOwnership/MapServer"
opacity: 0.4
url: "https://Server/arcgis/rest/services/WebMercator/PLSS/MapServer"
url:"https://Server/arcgis/rest/services/WebMercator/Lightning24hours/MapServer"
//ArcGISDynamicMapServiceLayer{
// id:incidents
// url:"https://Server/arcgis/rest/services/WRMS/Incidents/MapServer"
FeatureLayer{
featureTable: incidentsFeatureService
positionDisplay{
compass:Compass{
positionSource: PositionSource{
onPositionChanged: {
mainMap.locationPoint.valid = position.latitudeValid&&position.longitudeValid;
mainMap.locationPoint.x = position.coordinate.longitude;
mainMap.locationPoint.y = position.coordinate.latitude;
locationPointChanged();
onError: {
console.log("There was an error with the Positional Display... Not sure as to why")
onMapReady:extent=oregonExtent
onMouseClicked: {
var features = incidentsFeatureLayer.findFeatures(mouse.x,mouse.y,0,1);
for (var i=0;i<features.length;i++)
hitFeatureId =features[i];
getFields(features);
identifyDialog.title = "ObjectID" + hitFeatureId;;
identifyDialog.visible = true;
ServiceInfoTask{
SimpleDialog {
title: "Object ID: " + hitFeatureId
height: (column.height * 1.3) * scaleFactor
width: (column.width * 1.05) * scaleFactor
Column {
spacing: 5 * scaleFactor
anchors.centerIn: parent
Repeater {
model: fieldsModel
Row {
spacing: (80 * scaleFactor) - nameLabel.width
Label {
text: name + ": "
font.pixelSize: 10 * scaleFactor
Label {
text: value
onRejected: {
hitFeatureId = 0;
Envelope{
xMin:-13884932.6524728
xMax:-12942012.5881222
yMin:5152699.92331632
yMax:5836354.32813466
wkid: 102100
ListModel{
ListModel{
ListModel{
Rectangle{
color: "black"
height:parent.height/10
width:parent.width
opacity: .75
Text{
visible:positionSource.active
color:"white"
anchors.left: parent.left
anchors.leftMargin: 10
anchors.verticalCenter: parent
Button{
iconSource: "qrc:/Resources/GpsIcon.png"
width: parent.height - parent.height * .1
height: parent.height - parent.height * .1
anchors.verticalCenter: parent.verticalCenter
anchors.right: parent.right
anchors.rightMargin: 10
onClicked: {
positionSource.active = true;
compass.active = true;
console.log("Hey you just clicked the button to turn the gps on" + qsTr(mainMap.positionDisplay.mode.toString()))
function getFields( featureLayer ) {
fieldsModel.clear();
var fieldsCount = incidentsFeatureLayer.featureTable.fields.length;
for ( var f = 0; f < fieldsCount; f++ ) {
var fieldName = incidentsFeatureLayer.featureTable.fields[f].name;
attrValue = incidentsFeatureLayer.featureTable.feature(hitFeatureId).attributeValue(fieldName);
if ( fieldName !== "Shape" ) {
var attrString = attrValue;
fieldsModel.append({"name": fieldName, "value": attrString});
function locationPointChanged(){
latLonPostionalData.text = "Lat: "+positionSource.position.coordinate.latitude+" Lon: "+positionSource.position.coordinate.longitude+" Alt: "+positionSource.position.coordinate.altitude;
