Qt on IOS
4480
12-08-2014 03:00 PM
BrianLocke
Finally, though it took a couple of days.... (helps if you read the docs I guess....) got Runtime for Qt over on IOS..... problems is GPS location does not work.... centers in at 0,0 for wkid 4326.  Also any layers that use https: will not display?? getting this error??
QObject::connect: Incompatible sender/receiver arguments
  QNetworkSessionPrivateImpl::usagePoliciesChanged(QNetworkSession::UsagePolicies) --> QNetworkSession::usagePoliciesChanged(QNetworkSession::UsagePolicies)
hmmmm.... has me scratching my head and I must admit that I am still getting used to the cryptic error messages that Qt usually gives.
Taking a swing at things I am wondering if these issues have something to do with the Info.plist???? Do I need to add some keys??  I did read in the docs that Qt does support Https over rest... which I am doing??  Any suggestions ?? I know things are in Beta but was hoping to generate some excitement for Ipads.
LucasDanzinger
Esri Frequent Contributor
Brian,
For the GPS Position, this should work- we use this internally all the time. Can you share your code? The below code works for me on iOS (and other platforms).
import QtQuick 2.3
import QtQuick.Controls 1.2
import QtPositioning 5.3
import ArcGIS.Runtime 10.3
ApplicationWindow {
    width: 800
    height: 600
    title: "ios position"
    Map {
        anchors.fill: parent
        wrapAroundEnabled: true
        focus: true
        ArcGISTiledMapServiceLayer {
                url: "http://services.arcgisonline.com/ArcGIS/rest/services/NatGeo_World_Map/MapServer"
        positionDisplay {
                positionSource: PositionSource {
                onPositionChanged: {
                          console.log(position.coordinate.longitude);
                          console.log(position.coordinate.latitude);
    Button {
        anchors {
                left: parent.left
                top: parent.top
                 margins: 15
        text: "show position"
        onClicked: positionSource.active = true;
LucasDanzinger
And as far as the https, I gave this a try with an internal dynamic map service, and it works. In this case, it uses https, but doesn't require credentials. Are you using a different layer, such as a feature layer or tiled layer? Do you require the user to enter credentials? If so, please look at the User Credentials Online sample in the sample app. You can use the identify manager to notify if you require credentials or not.
ArcGISDynamicMapServiceLayer {
            url: "https://servername:6080/arcgis/rest/services/Map6/MapServer"
BrianLocke
Here is the code for the Location, I have tried this on an Ipad 2 and also an Air 2 with the same Results-publishing to Android works fine though .... Save there is no Compass support on Android.
I have removed the specific server as were not to make the Services Public Quite yet, Also Removing the s out of HTTPS: works?? the services have had the token removed and seem to work fine just using http?  This is odd because in the other runtimes this will not work (iOS, Android and .Net)... hmmmm
Thanks for the speedy response back
import QtQuick 2.1
import QtQuick.Controls 1.0
import QtQuick.Dialogs 1.2
import QtQuick.Window 2.0
import QtQuick.Layouts 1.1
import ArcGIS.Runtime.Toolkit.Dialogs 1.0
import QtSensors 5.3
ApplicationWindow {
    width: 320
    height: 480
    title: "WrmsLite"
Rectangle{
    property int hitFeatureId:0
    property variant attrValue
    property real scaleFactor: 1
    property bool settingsView: true
    states:[
    State{
            when:settingsDisplay
            changes:[
                PropertyChanges {
                    target: settingsDisplay
                    anchors.fill:parent},
                PropertyChanges{
                    target:mainMap
                    visible:false}
    Rectangle{
        color:"white"
    GeodatabaseFeatureServiceTable{
       url:"https://SERVER/arcgis/rest/services/WRMS/Incidents/MapServer/0"
    Map{
        property Point locationPoint: Point{
            property bool valid: false
            spatialReference: SpatialReference{
                wkid: 4326
        ArcGISTiledMapServiceLayer{
            url:"http://Server/arcgis/rest/services/USA_Topo_Maps/MapServer"
        ArcGISDynamicMapServiceLayer{
            url:"https://Server/arcgis/rest/services/WebMercator/PublicOwnership/MapServer"
            opacity: 0.4
            url: "https://Server/arcgis/rest/services/WebMercator/PLSS/MapServer"
            url:"https://Server/arcgis/rest/services/WebMercator/Lightning24hours/MapServer"
        //ArcGISDynamicMapServiceLayer{
           // id:incidents
           // url:"https://Server/arcgis/rest/services/WRMS/Incidents/MapServer"
        FeatureLayer{
            featureTable: incidentsFeatureService
        positionDisplay{
            compass:Compass{
                positionSource: PositionSource{
                    mainMap.locationPoint.valid = position.latitudeValid&&position.longitudeValid;
                    mainMap.locationPoint.x = position.coordinate.longitude;
                    mainMap.locationPoint.y = position.coordinate.latitude;
                    locationPointChanged();
                onError: {
                    console.log("There was an error with the Positional Display... Not sure as to why")
        onMapReady:extent=oregonExtent
        onMouseClicked: {
            var features = incidentsFeatureLayer.findFeatures(mouse.x,mouse.y,0,1);
            for (var i=0;i<features.length;i++)
                hitFeatureId =features[i];
                getFields(features);
                identifyDialog.title = "ObjectID" + hitFeatureId;;
                identifyDialog.visible = true;
    ServiceInfoTask{
    SimpleDialog {
            title: "Object ID: " + hitFeatureId
            height: (column.height * 1.3) * scaleFactor
            width: (column.width * 1.05) * scaleFactor
            Column {
                spacing: 5 * scaleFactor
                anchors.centerIn: parent
                Repeater {
                    model: fieldsModel
                    Row {
                        spacing: (80 * scaleFactor)  - nameLabel.width
                        Label {
                            text: name + ": "
                            font.pixelSize: 10 * scaleFactor
                        Label {
                            text: value
            onRejected: {
                hitFeatureId = 0;
    Envelope{
        xMin:-13884932.6524728
        xMax:-12942012.5881222
        yMin:5152699.92331632
        yMax:5836354.32813466
            wkid: 102100
    ListModel{
    ListModel{
    ListModel{
    Rectangle{
        color: "black"
        height:parent.height/10
        width:parent.width
        opacity: .75
        Text{
            visible:positionSource.active
            color:"white"
            anchors.left: parent.left
            anchors.leftMargin: 10
            anchors.verticalCenter: parent
        Button{
            iconSource: "qrc:/Resources/GpsIcon.png"
            width: parent.height - parent.height * .1
            height: parent.height - parent.height * .1
            anchors.verticalCenter: parent.verticalCenter
            anchors.right: parent.right
            anchors.rightMargin: 10
            onClicked: {
                compass.active = true;
                console.log("Hey you just clicked the button to turn the gps on" + qsTr(mainMap.positionDisplay.mode.toString()))
    function getFields( featureLayer ) {
          fieldsModel.clear();
          var fieldsCount = incidentsFeatureLayer.featureTable.fields.length;
          for ( var f = 0; f < fieldsCount; f++ ) {
              var fieldName = incidentsFeatureLayer.featureTable.fields[f].name;
              attrValue = incidentsFeatureLayer.featureTable.feature(hitFeatureId).attributeValue(fieldName);
              if ( fieldName !== "Shape" ) {
                  var attrString = attrValue;
                  fieldsModel.append({"name": fieldName, "value": attrString});
    function locationPointChanged(){
        latLonPostionalData.text = "Lat: "+positionSource.position.coordinate.latitude+" Lon: "+positionSource.position.coordinate.longitude+" Alt: "+positionSource.position.coordinate.altitude;
