IF Then Else statements in Field Calculator
3002
12-02-2014 11:58 PM
StephenConner
I have been going through the forum and trying everything.  Maybe someone here can see where i have gone wrong.
I amd calculating the percent change and have come across only one of my properties with no value, which gives me the error of dividing by zero.  So I am using if then else statements to avoid it.  Here is the Pre-logic:
Dim Per1314
If [LVal2013] = 0 Then
Per1314 = 0
Else
Per1314 = [Diff1314] / [LVal2013]*100
End If
Where am I going wrong?   FYI: Arcgis 10.2.2
Pieter_Geertvan_den_Beukel
an empty value is different from a 0 (zero).
Try:
If [LVal2013] is null Then
Try:
