How do I get a pane to move using dojo Moveable?
1944
12-02-2014 12:09 PM
ChrisSergent
I have a working editor widget but I want to be able to move the pane based on onmousedown. I used this example here: dojo/dnd/Moveable — The Dojo Toolkit - Reference Guide
This is the block of code that is supposed to allow me to move the pane:
on(dom.byId("templatePickerPane"), "onmousedown", function () {
      var dnd = new Moveable(dom.byId("templatePickerPane"));
Any idea how I get this object to move on mouse down? Here is my code:
<!DOCTYPE html>
<html>
    <head>
        <title>Decatur Graphics Editor</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
                position:absolute;
                z-index:0;
            /* Editor style begin */
            #templatePickerPane {
                width: 200px;
                height:300px;
                overflow: hidden;
                z-index:50;
                top:50%;
                right:0%;
                position:absolute;
            #panelHeader
                background-color: #92A661;
                border-bottom: solid 1px #92A860;
                color: #FFF;
                font-size: 18px;
                height: 24px;
                line-height: 22px;
                margin: 0;
                overflow: hidden;
                padding: 10px 10px 10px 10px;
            #editorDiv
                background-color:White;
              .esriEditor .templatePicker
                padding-bottom: 5px;
                padding-top: 5px;
                height: 500px;
                border-radius: 0px 0px 4px 4px;
                border: solid 1px #92A661;
              .dj_ie .infowindow .window .top .right .user .content, .dj_ie .simpleInfoWindow .content
                position: relative;
            /* Editor Style End */
    </style>
        <script src="http://js.arcgis.com/3.11/" type="text/javascript"></script>
        <script type="text/javascript">
            var map;
            require(["esri/map", "esri/config",
                     "esri/geometry/Extent",
                     "esri/dijit/editing/Editor",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/SnappingManager",
                     "esri/tasks/GeometryService",
                     "esri/toolbars/draw",
                     "dojo/dom",
                     "dojo/keys",
                     "dojo/on",
                     "dojo/parser",
                     "dojo/_base/array",
                     "dojo/i18n!esri/nls/jsapi",
                     "dojo/dnd/Moveable",
                     "dojo/domReady!"], function (Map, esriConfig, Extent, Editor, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
                                                  FeatureLayer, SnappingManager, GeometryService, Draw, dom, keys, on, parser, arrayUtils, i18n, Moveable
                         parser.parse();
                         //snapping is enabled for this sample - change the tooltip to reflect this
                         i18n.toolbars.draw.start += "<br/>Press <b>CTRL</b> to enable snapping";
                         i18n.toolbars.draw.addPoint += "<br/>Press <b>CTRL</b> to enable snapping";
                         /* The proxy comes before all references to web services */
                         /* Files required for security are proxy.config, web.config and proxy.ashx
                         - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
                         (Roles are not required)
                         The proxy section is defined on the ESRI sample. I have included it as
                         part of the documentation reads that the measuring will not work.
                         I thought that might be important.
                         // Proxy Definition Begin
                         //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
                         //If this null or not available the project and lengths operation will not work.
                         // Otherwise it will do a http post to the proxy.
                         esriConfig.defaults.io.proxyUrl = "proxy.ashx";
                         esriConfig.defaults.io.alwaysUseProxy = true;
                         // Proxy Definition End
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         map.on("layers-add-result", initEditing);
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // add point feature layer
                         var pointFeatureLayer = new FeatureLayer("http://maps.decaturil.gov/arcgis/rest/services/Test/FeatureServer/0", {
                             mode: FeatureLayer.MODE_ONDEMAND,
                             outFields: ["*"]
                         map.addLayers([pointFeatureLayer]);
                         map.infoWindow.resize(400, 300);
                         function initEditing(event) {
                             var featureLayerInfos = arrayUtils.map(event.layers, function (layer) {
                                 return {
                                     "featureLayer": layer.layer
                             var settings = {
                                 map: map,
                                 layerInfos: featureLayerInfos
                             var params = {
                                 settings: settings
                             var editorWidget = new Editor(params, 'editorDiv');
                             editorWidget.startup();
                             var options = { snapKey: keys.copyKey };
                             map.enableSnapping(options);
        </script>
    </head>
    <body class="soria">
      <div id="mapDiv">
      </div>
      <div id="templatePickerPane">
        <div id="panelHeader">
          Default Editor
        </div>
        <div style="padding:10px;" id="editorDiv">
        </div>
      </div>
  </body>
</html>
ChrisSergent
If you have this question, I changed my line to the following to make it work:
on(Moveable(dom.byId("templatePickerPane")), "onmousedown", function () {
