Grouping layers in the layer list widget
9195
8
11-26-2014 12:38 AM
PabloIzquierdo1
Is there any way to group layers by categories in the layer list widget?
In this previous conversation, I found a map (http://maps.cityoftulsa.org/iot/) with exactly the kind of layer list that we are looking for. But I have the feeling that this is only possible if we publish the mxd with ArcGIS for Server.
RobertScheitlin__GISP
Pablo,
   You are correct. The only reason that those layers are grouped is because they are done so in the Map Service. There is no OTB grouping capability in the Layer List Widget.
Pablo,
ShannonGrumbly2
Hi Robert,
Will the layers be grouped in a Map Service (and thus an ArcGIS Online web application) via a Feature Dataset or by simply grouping them in the Table of Contents?
Just grouping in the TOC.
ShannonGrumbly2
Perfect, thank you!
GeraldLee_
Hey Robert,
Do you know of any way to group Image Services inside the layerlist widget or web map?
Gerald
(Hope to see you at Dev Summit again this year-
Gerald,
  I don't use image server but if you group the layers in ArcMap then the LayerList will have them grouped.
(yep, see you at the Dev Summit)
BrianO_keefe
Honored Contributor
That's how I set up that map. I think you can do this from Catalog too, by publishing the data directly to ArcGIS for Server but I'm not 100% certain on that.
PabloIzquierdo1
Thanks guys, I really appreciate your help
