Trying to get the Print webmap to work with our map server
6207
7
11-24-2014 08:17 AM
ChrisSergent
We have our own map server and I am trying to use the Print webmap example to create our print task, but it's not working. There is an error stating this is not a defined function:
map.then(function (resp) {
                             app.mapInfo = resp.itemInfo.item;
                             app.map = resp.map;
                             createPrintDijit(app.mapInfo.title);
I am using the example located at: Print webmap | ArcGIS API for JavaScript
The reason that I am using this code is that the print example does not show you how the code selects the type of printout:  Print | ArcGIS API for JavaScript
Any ideas how I get this to work?
Here is my code:
<!DOCTYPE html>
<html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
                position:absolute;
                z-index:0;
            /* Printer CSS Begin */
            h3 { margin: 0 0 5px 0;
                 border-bottom: 1px solid #444;
                 padding: 0 0 5px 0;
                 text-align: center;
              .shadow
                -moz-box-shadow: 0 0 5px #888;
                -webkit-box-shadow: 0 0 5px #888;
            #feedback
                background: #fff;
                border: 2px solid #666;
                border-radius: 5px;
                bottom: 20px;
                color: #666;
                font-family: arial;
                height: auto;
                left: 20px;
                top:50%;
                margin: 5px;
                padding: 10px;
                position: absolute;
                width: 300px;
                z-index: 40;
            #feedback a
                border-bottom: 1px solid #888;
                color: #666;
                text-decoration: none;
            #feedback a:hover, #feedback a:active, #feedback a:visited {
                border: none;
                color: #666;
            #note
                padding: 0 0 10px 0;
            #info, #information
                padding: 10px 0 0 0;
            /* Printer CSS End */
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            var app = {};
            require(["esri/map", "esri/config",
                     "esri/dijit/Print",
                     "esri/geometry/Extent",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/tasks/GeometryService",
                     "esri/tasks/PrintTemplate",
                     "dojo/_base/array",
                     "dojo/dom",
                     "dojo/on",
                     "dojo/parser",
                     "dijit/layout/BorderContainer",
                     "dijit/layout/ContentPane",
                     "dojo/domReady!"], function (Map, esriConfig, Print, Extent,
                                                  ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
                                                  FeatureLayer, GeometryService, PrintTemplate, arrayUtils, dom, on, parser
                         /* The proxy comes before all references to web services */
                         /* Files required for security are proxy.config, web.config and proxy.ashx
                         - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
                         (Roles are not required)
                         The proxy section is defined on the ESRI sample. I have included it as
                         part of the documentation reads that the measuring will not work.
                         I thought that might be important.
                         // Proxy Definition Begin
                         //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
                         //If this null or not available the project and lengths operation will not work.
                         // Otherwise it will do a http post to the proxy.
                         esriConfig.defaults.io.proxyUrl = "proxy.ashx";
                         esriConfig.defaults.io.alwaysUseProxy = false;
                         // Proxy Definition End
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         var map = new Map("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
                             app.map = resp.map;
                         function createPrintDijit(printTitle) {
                             var layoutTemplate, templateNames, mapOnlyIndex, tempplates;
                             // create an array of object that will be used to create print templates
                             var layouts = [{
                                 name: "Letter ANSI A Landscape",
                                 label: "Landscape (PDF)",
                                 format: "pdf",
                                 options: {
                                     legendLayers: [], // empty array means no legend
                                     scalebarUnit: "Miles",
                                     titleText: printTitle + ", Landscape PDF"
                                 name: "Letter ANSI A Portrait",
                                 label: "Portrait (Image)",
                                 format: "jpg",
                                 options: {
                                     legendLayers: [],
                                     titleText: printTitle + ", Portrait JPG"
                             // create print templates
                             var templates = arrayUtils.map(layouts, function (lo) {
                                 var t = new PrintTemplate();
                                 t.layout = lo.name;
                                 t.label = lo.label;
                                 t.format = lo.format;
                                 t.layoutOptions = lo.options;
                                 return t;
                             app.printer = new Print({
                                 map: app.map,
                                 templates: templates,
                                 url: app.printUrl
                             }, dom.byId("print_button"));
                             app.print.startup();
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv">
            <!-- Feedback Begin -->
            <div id="feeback">
                <h3>
                    ArcGIS.com Webmap and the Print Dijit
                </h3>
                <!-- Info Begin -->
                <div id="info">
                    <!-- Note Begin -->
                    <div id="note">
                        Note:  This sample uses an ArcGIS Server version 10.1 export web map task.
                    </div>
                    <!-- Note End -->
                    <!-- Used for the print dijit -->
                    <div id="print_button"></div>
                    <!-- Info Begin -->
                    <div id="information">
                        The map is <a href="https://developers.arcgis.com/javascript/jsapi/esri.arcgis.utils-amd.html#createmap">created from an ArcGIS.com webmap</a> and
                        <a href="https://developers.arcgis.com/javascript/jsapi/printtemplate-amd.html">print templates</a> are
                        created manually. Refer to the documentation for more print template options (output formats, additional layouts, etc.).
                    </div>
                    <!-- Information End -->
                </div>
                <!-- Info End -->
            </div>
            <!-- Feeback End -->
        </div>
    </body>
</html>
Tags (1)
KellyHutchins
Esri Frequent Contributor
There are still several issues with your app. In the code where you create Print you set the map constructor option to app.map and no app.map exists. I also don't see app.printUrl defined anywhere in your code. Finally you call startup on app.print when it should be app.printer.
                                 map: app.map,
                                 url: app.printUrl
KellyHutchins
The original sample used a web map id along with the createMap method. The createMap method takes a web map id and the response contains a map along with info about the web map. So the following code that you have in your sample won't work for a regular map. Try removing this code and just call createPrintDijit with a string value you want to use for the title.
                             app.map = resp.map;
ChrisSergent
I removed that block and replaced it with
createPrintDijit("Print Map");
I also added the following line before my proxy information:
parser.parse();
I am now receiving an error when I attempt to select one of the print options: Uncaught TypeError: Cannot read property 'layerIds' of undefined PrintTask.js:21
KellyHutchins
                                 map: app.map,
                                 url: app.printUrl
ChrisSergent
Yea, a URL would've definitely have helped. I added that in; caught my typo before, but I changed the map:app.map to map:map and it's working now. Thanks again.
GabiVoicu
I'm trying to do the same thing and I would appreciate if I could use your working version code as an example and try to follow same steps!
Thank you so very, very much
ChrisSergent
No problem. All my code is always free to use. Here is a working copy: JS Bin - Collaborative JavaScript Debugging
GabiVoicu
You are the best !
Thank you so very much – I owe you ☺
