Problems with defined proxy page. What am I doing wrong?
2874
11-21-2014 01:18 PM
ChrisSergent
I am trying to add proxy information to my site and my JavaScript, but it's returning errors. I don't need these urls to be secure. The following is my code for my application and my proxy.config file for the application published at: maps.decaturil.gov/decaturPrint
App Code:
<!DOCTYPE html>
<html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/soria/soria.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
                width:100%;
            #feedback
                background: #fff;
                border: 2px solid #666;
                border-radius: 5px;
                bottom: 20px;
                color: #666;
                font-family: arial;
                height: auto;
                left: 20px;
                margin: 5px;
                padding: 10px;
                position: absolute;
                width: 300px;
                z-index: 40;
            #feedback a
                border-bottom: 1px solid #888;
                color: #666;
                text-decoration: none;
            #feedback a:hover, #feedback a:active, #feedback a:visited {
                border: none;
                color: #666;
            #note
                padding: 0 0 10px 0;
            #info
                padding: 10px 0 0 0;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            require(["esri/map", "esri/config",
                     "esri/arcgis/utils",
                     "esri/dijit/Print",
                     "esri/geometry/Extent",
                     "esri/layers/ArcGISDynamicMapServiceLayer",
                     "esri/layers/ArcGISTiledMapServiceLayer",
                     "esri/layers/FeatureLayer",
                     "esri/tasks/GeometryService",
                     "esri/tasks/PrintTemplate",
                     "dojo/_base/array",
                     "dojo/dom",
                     "dojo/on",
                     "dojo/parser",
                     "dijit/layout/BorderContainer",
                     "dijit/layout/ContentPane",
                     "dojo/domReady!"], function (Map, esriConfig, arcgisutils, Print, Extent,
                                                  ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer,
                                                  FeatureLayer, GeometryService, PrintTemplate, arrayUtils, dom, on, parser
                         /* The proxy comes before all references to web services */
                         /* Files required for security are proxy.config, web.config and proxy.ashx
                         - set security in Manager to Private, available to selected users and select Allow access to all users who are logged in
                         (Roles are not required)
                         The proxy section is defined on the ESRI sample. I have included it as
                         part of the documentation reads that the measuring will not work.
                         I thought that might be important.
                         // Proxy Definition Begin
                         //identify proxy page to use if the toJson payload to the geometry service is greater than 2000 characters.
                         //If this null or not available the project and lengths operation will not work.
                         // Otherwise it will do a http post to the proxy.
                         esriConfig.defaults.io.proxyUrl = "proxy.ashx";
                         esriConfig.defaults.io.alwaysUseProxy = true;
                         // Proxy Definition End
                         // set custom extent
                         var initialExtent = new Extent({
                             "xmin": 777229.03,
                             "ymin": 1133467.92,
                             "xmax": 848340.14,
                             "ymax": 1185634.58,
                             "spatialReference": {
                                 "wkid": 3435
                         // create map and set slider style to small
                         var map = new arcgisutils.createMap("mapDiv", {
                             showAttribution: false,
                             sliderStyle: "small",
                             extent: initialExtent
                         // add imagery
                         var tiled = new ArcGISTiledMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                         map.addLayer(tiled);
                         // set operational layers
                         var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                         // add operational layers
                         map.addLayer(operationalLayer);
                         // declare geometry service
                         esriConfig.defaults.geometryService = new GeometryService("http://maps.decaturil.gov/arcgis/rest/services/Utilities/Geometry/GeometryServer");
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv"></div>
    </body>
</html>
proxy.config file
<?xml version="1.0" encoding="utf-8" ?>
<ProxyConfig allowedReferers="*"
             mustMatch="false">
    <serverUrls>
        <!-- serverUrl options:
            url = location of the ArcGIS Server, either specific URL or stem
            matchAll = true to forward any request beginning with the url
            token = (optional) token to include for secured service
            dynamicToken = if true, gets token dynamically with username and
              password stored in web.config file's appSettings section.
        <serverUrl url="http://maps.decaturil.gov/arcgis/rest/services"
                   matchAll="true">
        </serverUrl>
    </serverUrls>
</ProxyConfig>
<!-- See https://github.com/Esri/resource-proxy for more information -->
Tags (1)
JakeSkinner
Esri Esteemed Contributor
Hi Chris,
If the proxy.ashx file is within the same folder as your application, your proxy should work.  If it's not, you will need to update the path to the proxy.ashx file.  For example:
esriConfig.defaults.io.proxyUrl = "http://<server name>/proxy/proxy.ashx";
In the above, I'm specifying to read the proxy.ashx in a folder called 'proxy' on a web server.
I believe you are receiving errors because you are trying to construct a map using the esri.arcgis.utils class, but you are not working with a web map.  Try using the Map class.  Ex:
<!DOCTYPE html>
<html>
  <head>
    <style>
      html, body, #mapDiv {
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #feedback {
        background: #fff;
        border-radius: 5px;
        bottom: 20px;
        color: #666;
        font-family: arial;
        height: auto;
        left: 20px;
        margin: 5px;
        padding: 10px;
        position: absolute;
        width: 300px;
        z-index: 40;
      #feedback a {
        color: #666;
        border: none;
        color: #666;
      #note {
      #info {
    </style>
    <script>
      var map;
      require([
        "esri/map", "esri/config", "esri/arcgis/utils", "esri/dijit/Print",
        "esri/geometry/Extent", "esri/layers/ArcGISDynamicMapServiceLayer", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/FeatureLayer",
        "esri/tasks/GeometryService", "esri/tasks/PrintTemplate", "dojo/_base/array",
        "dojo/dom", "dojo/on", "dojo/parser",
        "dijit/layout/BorderContainer", "dijit/layout/ContentPane", "dojo/domReady!"
      ], function(
        Extent, ArcGISDynamicMapServiceLayer, ArcGISTiledMapServiceLayer, FeatureLayer,
        dom, on, parser) {
          "xmin" : 777229.03,
          "ymin" : 1133467.92,
          "xmax" : 848340.14,
          "ymax" : 1185634.58,
          "spatialReference" : {
            "wkid" : 3435
        var map = new Map("mapDiv", {
          showAttribution : false,
          sliderStyle : "small",
          extent : initialExtent
          "opacity" : 0.5
    </script>
  </head>
  </body>
</html>
JakeSkinner
Hi Chris,
<!DOCTYPE html>
<html>
  <head>
    <style>
        padding: 0;
        margin: 0;
        height: 100%;
        width: 100%;
      #feedback {
        background: #fff;
        border-radius: 5px;
        bottom: 20px;
        color: #666;
        font-family: arial;
        height: auto;
        left: 20px;
        margin: 5px;
        padding: 10px;
        position: absolute;
        width: 300px;
        z-index: 40;
      #feedback a {
        color: #666;
        border: none;
        color: #666;
      #note {
      #info {
    </style>
    <script>
      var map;
      require([
      ], function(
        dom, on, parser) {
          "xmin" : 777229.03,
          "xmax" : 848340.14,
            "wkid" : 3435
          "opacity" : 0.5
    </script>
  </head>
  </body>
</html>
ChrisSergent
My proxy was right. The error was the esri.arcgis.utils. Thanks.
