Influence parameter in Python toolbox
4360
11-21-2014 03:18 AM
TomGeo
I have the issue that I want to set value of a parameter from within the updateParameters function in a Python toolbox.
The parameter is defined like this:
def getParameterInfo(self):
     in_fc_mark = arcpy.Parameter(
            displayName="Field Data (calculation year)",
            name="pln_classes",
            datatype="String",
            parameterType="Required",
            direction="Input")
     # Define calculation year
     int_today = datetime.datetime.today().year
     in_int_year = arcpy.Parameter(
         displayName="Calculation Year",
         name="str_years",
         datatype="GPLong",
         direction="Input")
     in_int_year.filter.type = "Range"
     in_int_year.filter.list = [1980, int_today+1]
     parameters = [in_fc_mark,
                   in_int_year]
     return parameters
and I would like to set the value for it this way:
def updateParameters(self, parameters):
     if parameters[0].altered:
          str_file = datetime.datetime.strftime(dparser.parse(os.path.basename(parameters[0].valueAsText), fuzzy=True),'%Y%m%d')
          if str_file[:4].isdigit():
               parameters[1].value(int(str_file[:4]))
     return
However, it doesn't work. I can enable parameters of type "GPBoolean" with parameters[1].enabled = True, but setting the value gives me trouble. How can I do this?
Bests, Thomas
- We are living in the 21st century.
GIS moved on and nobody needs a format consisting out of at least three files! No, nobody needs shapefiles, not even for the sake of an exchange format. Folks, use GeoPackage to exchange data with other GIS!
Tags (1)
DallasShearer
maybe try changing the update statement to this.
     if not parameters[1].altered:
               arcpy.AddMessage(int(str_file[:4]))
     return
TomGeo
Thanks Dallas,
the stupid thing still comes back saying: File "<string>", line 174, in updateParameters TypeError: 'NoneType' object is not callable
TomGeo
Okay, I just found it... Well, to assign a value you have to say:
parameters[1].value = int(str_file[:4])
So, now it works without any problems.
