I am having some trouble with a view controller that retains a lot of memory after popping, and never deallocates.
viewDidDisappear() is fired, but dealloc() is never called.
Turns out, when I skip adding the AGSTiledMapServiceLayer (created using [tiledMapServiceLayerWithURL], everything works as expected and dealloc() is called on my view-controller.. and memory is released.
Anybody else experienced this ?
I am currently using Runtime 10.2.4.
Solved! Go to Solution.
Turned out that the leak was caused by some ugly code executed during mapViewDidLoad().
Problem solved !
Problem solved !
