Geocoding intersections problem
4598
11-18-2014 06:07 PM
AndrellBower
I have a file of street names joined by the "&" symbol that I would like to geocode as intersections. I created an address locater with the style 'US Address - Dual Ranges' based on the streets file my county publishes. When I try to geocode, the geocoder will say it's completed after attempting to geocode only a few rows. Does anyone know why this is happening? I tried changing my spelling sensitivity, and I've also tried doing a test with fewer rows where I made sure the road names were spelled exactly the same and had the right suffixes and prefixes, but I still can't get the geocoder to complete with all the rows in my file.
Thanks!
ShanaBritt
Andrell:
Are you able to provide the table that you are geocoding along with the address locator and data used to build the locator? This will help to troubleshoot the behavior you encountered.
-Shana
JoeBorgione
What version of ArcGIS are you using?  What version of locators?
edited later....  Shana Britt​ looks like the op is a couple years old.  Maybe he figured it out?
