Featurelayer highlight vs select
4885
6
11-18-2014 04:59 PM
EdwardSohn2
What is the best way to "highlight" a feature on a featurelayer, or a graphic on a graphicslayer, much in the same way a feature is highlighted when user clicks on it to show the InfoWindow (but without showing the InfoWindow).  This is different from the selection of a feature which is controlled by setting the selection symbol.  Also do not want to actually select the feature if possible.
(Usually the highlight feature surrounds the feature with a box with a cross overlaid on it.)
Thanks.
RobertScheitlin__GISP
Edward,
  I think this sample is what you are looking for (be aware the use of the "target" SMS style is undocumented and subject to change):
<!DOCTYPE html>
<html>
<head>
  <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no" />
  <title>Drop Down Test</title>
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/dojo/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.10/js/esri/css/esri.css">
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      background-color: #FFF;
      overflow: hidden;
      font-family: "Trebuchet MS";
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script src="http://js.arcgis.com/3.10/"></script>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/on",
      "esri/tasks/query",
      "esri/graphic",
      "esri/layers/FeatureLayer",
      "esri/symbols/SimpleMarkerSymbol",
      "esri/symbols/CartographicLineSymbol",
      "esri/Color",
      "dojo/store/Memory",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/json",
      "dojo/parser",
      "dijit/registry",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dijit/form/Button",
      "dijit/form/ComboBox",
      "dojo/domReady!"
    ], function(
      Map, on, Query, Graphic, FeatureLayer, SimpleMarkerSymbol, CartographicLineSymbol, Color, Memory, array, lang, esriRequest, json, parser, registry
      parser.parse();
      map = new Map("map", {
        basemap: "topo",
        center: [-120.1883, 37.0868],
        zoom: 6
      var vendors = new FeatureLayer("http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/ALL_City_Vendors/FeatureServer/0", {
        outFields: ["*"]
      //point target symbol
      var cls = new CartographicLineSymbol(CartographicLineSymbol.STYLE_SOLID, new Color([0,255,255,1]), 2, CartographicLineSymbol.CAP_ROUND, CartographicLineSymbol.JOIN_ROUND);
      var sms = new SimpleMarkerSymbol("target", 16, cls, new Color([0,0,0,0]));
      sms._spikeSize = 7;
      sms._targetHeight = 17;
      sms._targetWidth = 17;
      sms.setAngle(0);
      map.addLayers([vendors]);
      map.on("layers-add-result", lang.hitch(this, function(){
        var url = "http://services.arcgis.com/V6ZHFr6zdgNZuVG0/ArcGIS/rest/services/ALL_City_Vendors/FeatureServer/0/ge...";
        var classificationDef = {"type":"uniqueValueDef","uniqueValueFields":["Vendor_Name"]};
        var str = json.stringify(classificationDef);
        esriRequest({
          url:url,
          content:{
            classificationDef:str,
            f:'json'
          handleAs:'json',
          callbackParamName:'callback',
          timeout:15000
        }).then(lang.hitch(this,function(response){
          var uniqueValueInfos = response && response.uniqueValueInfos;
          if(uniqueValueInfos){
            var store2 = new Memory({data:[]});
            registry.byId("uniqueValuesSelect").set('store',store2);
            var data = array.map(uniqueValueInfos,lang.hitch(this,function(info,index){
              var value = info.value;
              //value = parseFloat(value);
              var dataItem = {
              return dataItem;
            store2 = new Memory({data:data});
        }),lang.hitch(this,function(error){
          console.error(error);
      registry.byId("clearBtn").on("click", function(){
        map.graphics.clear();
      registry.byId("uniqueValuesSelect").on("change", function(){
        var query = new Query();
        query.where = "Vendor_Name='" + registry.byId("uniqueValuesSelect").get('value') + "'";
        console.info(query.where);
        query.returnGeometry = true;
        vendors.queryFeatures(query, function (featureSet) {
          var Geom = featureSet.features[0].geometry;
          var gra = new Graphic(Geom, sms);
          map.graphics.add(gra);
          map.centerAndZoom(Geom, 16);
  </script>
</head>
<body class="claro">
  <div id="mainWindow" data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:false" style="padding:0px;margin:0px;">
    <div id="header" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'top'" style="overflow:hidden;border:none;border-bottom: 3px solid #CC9900;font-family: Windows;font-size:14pt; color: #FFFFFF;background: #000000; "> Select a Vendor name and it will be selected and zoomed to it on the map:
      <select id="uniqueValuesSelect" data-dojo-type="dijit/form/ComboBox"></select>
      <button id="clearBtn" data-dojo-type="dijit/form/Button">Clear Selection</button>
    </div>
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'left'" style="width:100%;height:95%;border:none;padding:0px;margin:0px;"></div>
  </div>
</body>
</html>
Edward,
<!DOCTYPE html>
<html>
<head>
  <style>
    html,
    body,
    #mainWindow {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    body {
      overflow: hidden;
    #header {
      height: 3%;
      overflow: auto;
  </style>
  <script>
    var map;
    require([
      "esri/map",
      "dojo/on",
      "esri/tasks/query",
      "esri/graphic",
      "esri/Color",
      "dojo/_base/array",
      "dojo/_base/lang",
      "esri/request",
      "dojo/json",
      "dojo/parser",
      "dijit/registry",
      "dojo/domReady!"
    ], function(
      parser.parse();
        basemap: "topo",
        zoom: 6
        outFields: ["*"]
      sms._spikeSize = 7;
      sms.setAngle(0);
        esriRequest({
          url:url,
          content:{
            f:'json'
          handleAs:'json',
          timeout:15000
              var dataItem = {
              return dataItem;
  </script>
</head>
    </div>
  </div>
</body>
</html>
EdwardSohn2
Thank you.  Will look at it.
Is there a best way to do the same for polylines and polygon shapes?
EdwardSohn2
Figured out for polygons.  I guess for polylines, just use SimpleLineSymbol..?
Edward,
   Correct just use a SimpleLineSymbol.
Don't forget to mark this thread as answered, by clicking the "Correct Answer" button on the reply that answered your question.
EdwardSohn2
Is there a way to prevent the mouse-over and mouse-out events for the map.graphics layer or for a separate graphics layer?  The issue is as follows.  I am highlighting (not selecting) a feature as user mouse over it.  It works, however the addition of the highlight symbol (above) to the featurelayer is causing additional unwanted mouse-over/out events to be fired because of the overlaying of the highlight graphic over the featurelayer.  This is causing multiple mouse-over/out events to be fired causing the highlight symbol to flicker.
Events:
featurelayer: mouse-over (highlight graphic is added over the feature)
featurelayer: mouse-out (highlight graphic is removed)
highlight graphic: mouse-over
highlight graphic: mouse-out
etc... as mouse moves over the feature.
This is happening even though there is no mouseover/out event handlers defined for the highlight graphics/layer.
One way to prevent this may be to prevent the mouseover/out events for the highlight graphics layer so only one set of events is fired:
Perhaps the highlight graphic can be added to a separate graphicslayer and put this at bottom of the layer ordering under the featurelayer?
EdwardSohn2
I figured out!
Thanks for your replies.
