Refresh Maps on Device
7361
5
11-12-2014 09:25 AM
TonyGroeneveld
Is there another way to refresh maps on the device other than signing out and signing back in?
In the testing / prototyping phase I'm in right now I am making lots of changes to my maps in ArcGIS online and then want to see the resulting behavior in collector with the new map.  The only way that I know to get the new map is to sign out and sign back in.
Is there another way?
RussRoberts
Esri Notable Contributor
iOS you can pull to refresh and then reload the map and that will grab any changes you made to the web map. On Android there is an overflow menu at the bottom and there is a refresh option and then you can reopen the map and it will grab the latest changes.
RussRoberts
KeisukeNozaki
Russell, is there a way to refresh automatically?
This is important when tracking where collectors went.
Please let me know.
Thank you.
KeisukeNozaki
For our iPad Mini  (iOS 8.1.1 Collector 10.2.7), pulling to refresh did not update the map.
Instead, pulling to refresh then clicking Offline (select Cancel) changed the map.
Is this a known issue?
RobertTaylor2
Doesn't work for me either using new Collector v 18.1.0 on iOS 12.1.1.  Not even signing out and signing back in works.  Really need to know how to ensure that latest version of webmap is being used.
BradBolton
I have consistently had this issue with Collector (iOS). I still can't seem to find a solution. Thankfully the one map that gets used in Collector doesn't need to be updated often. However, during the times I am making changes, I can't get the map to update. Numerous sign out/in attempts, and ending the app does nothing. My experience has been that after a random period of time, it updates. I just tried pulling down to refresh after adding a new layer to my map. Layer shows up in Explorer app (always updates after a sign out/in), but not Collector. I don't have the iPad in front of me, but I know it does not have the very latest software update on it. Not sure if that matters.
