Adding text field changing size to "max"
4502
7
11-10-2014 09:45 AM
AaronHeyman
I add a text field of size 5000 to an existing table using arcmap.  All looks good.  Publish the table within a service and the service reports it as:
NOTES ( type: esriFieldTypeString , alias: NOTE , editable: true , nullable: true , length: 1073741822 )
Looking at the table in arcmap the size is now showing as 1,073,741,822.  Anyone else have this issue and know what I do to fix it?  The service on the table does not work unless I remove that field.
Aaron
XanderBakker
Esri Esteemed Contributor
Maybe it has something to do with this issue:
Text data type and Length size problem
Kind regards, Xander
XanderBakker
AaronHeyman
Reading the link above I found out that the make size for a NVARCHAR field in my mssql database was 4000.  MS's site said to deduct 2 from the length so it will not create as size max.
FNOTES ( type: esriFieldTypeString , alias: FNOTES , editable: true , nullable: true , length: 3998 )
Thanks for the help.  The service is working.
AsrujitSengupta
Version of ArcGIS Desktop? Complete version of DBMS used?
AaronHeyman
ArcMap 10.2.0.3348, License Type: Standard
GeoDatabase (MSSQL):  10.2.1
AsrujitSengupta
By "Complete version of DBMS used?", I meant the backend database version (e.g: SQL Server 2012, Oracle 11.2.0.3, PostgreSQL 9.0.5, etc)
AaronHeyman
Microsoft SQL Server 2008 R2 (RTM) - 10.50.1600.1 (X64)
  Apr  2 2010 15:48:46
  Copyright (c) Microsoft Corporation
  Enterprise Edition (64-bit) on Windows NT 6.1 <X64> (Build 7600: ) (Hypervisor)
I got that by running the command "select @@version".
