Simple question
3547
6
11-10-2014 05:44 AM
KarenSnitzer
New student here...
I am trying to select by attributes, but when I put in the query, no records are selected.  I looked at one record in the table and there are multiple features under the tree.  Can this be causing the problem?  And how can I get around it?
Thanks.
StevenGraf1
You could write your query as such also:
"LANDCODE" IN ('941', '980', '910', '940', '930', '734')
Here is a SQL Query Reference Guide.
Steven
TimWitt2
Hi Karen,
Can you post your query here?
Tim
KarenSnitzer
When I selected each row manually from the attribute table and made it into a layer it worked.
Here is how I did the query tho for those attributes:
LANDCODE = '941' AND LANDCODE = '980' AND LANDCODE = '910' AND LANDCODE = '940' AND LANDCODE = '930' AND LANDCODE = '734'
I don't understand why it wouldn't do the same thing as selecting each row manually, tho. Can you explain?
Thanks!
KarenSnitzer
TimWitt2
Karen,
instead of AND use OR. When you use AND it looks for a row that has all of the LANDCODE you specify in it.
With OR it selects each number.
Tim
StevenGraf1
Steven
KarenSnitzer
Thanks!! I'll try both methods!
Karen
