How do I set the extent in AMD?
2091
11-07-2014 12:17 PM
ChrisSergent
I modified my code based on an example to set the extent, but it appears not to be working. Here is my code:
<!DOCTYPE html>
<html>
    <head>
        <title>Create a Map</title>
        <meta http-equiv="content-type" content="text/html; charset=utf-8">
        <meta name="viewport" content="initial-scale=1,maximum-scale=1, user-scalable=no">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
        <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
        </style>
        <script src="http://js.arcgis.com/3.11/"></script>
        <script>
            var map;
            require(["esri/map", "esri/layers/ArcGISTiledMapServiceLayer", "esri/layers/ArcGISDynamicMapServiceLayer",
            "dojo/dom", "dojo/on", "dojo/parser", "esri/geometry/Extent", "dojo/domReady!"], function (Map, Tiled, ArcGISDynamicMapServiceLayer, dom, on, parser, Extent
                map = new Map("mapDiv", {
                    showAttribution: false,
                    sliderStyle: "large"
                    // add imagery
                    var tiled = new Tiled("http://maps.decaturil.gov/arcgis/rest/services/Aerial_2014_Tiled/MapServer");
                    map.addLayer(tiled);
                    // set operational layers
                    var baseLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Base/MapServer");
                    var operationalLayer = new ArcGISDynamicMapServiceLayer("http://maps.decaturil.gov/arcgis/rest/services/Public/InternetVector/MapServer", { "opacity": 0.5 });
                    // add operational layers
                    map.addLayer(baseLayer);
                    map.addLayer(operationalLayer);
                    // set map extent
                    var extent = new Extent();
                    extent.xmin = 777229.03;
                    extent.ymin = 1133467.92;
                    extent.xmax = 848340.14;
                    extent.ymax = 1185634.58;
                    map.setExtent(extent);
        </script>
    </head>
    <body class="soria">
        <div id="mapDiv">
        </div>
    </body>
</html>
Tags (1)
TimWitt2
This should do it:
<!DOCTYPE html>
<html>
    <head>
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
        </style>
        <script>
            var map;
            var initialExtent = new Extent({"xmin":777229.03,"ymin":1133467.92,"xmax":848340.14,"ymax":1185634.58,"spatialReference":{"wkid":3435}});
                    sliderStyle: "large",
                    extent: initialExtent
                    // add imagery
        </script>
    </head>
        <div id="mapDiv">
        </div>
    </body>
</html>
TimWitt2
This should do it:
<!DOCTYPE html>
<html>
    <head>
        <style>
            html, body, #mapDiv
                padding:0;
                margin:0;
                height:100%;
        </style>
        <script>
            var map;
                    // add imagery
        </script>
    </head>
        <div id="mapDiv">
        </div>
    </body>
</html>
ChrisSergent
Thanks Tim. I am new to AMD. Some of it is still guess work for me, but this gets me closer to my starting template.
TimWitt2
No problem, good thing you start using it though!
