EnhancedGrid vs DataGrid for Print (mix code)
1176
11-06-2014 10:53 AM
JenniferZumbado-Hannibal1
Hi there,
I'm kinda new at programming so please excuse me if I ask stupid questions.
What I want to do is simple:
Show a Search grid inside an accordion left panel where it will print the grid with a button.
I've achieved doing the all of it until I get to the part where I want to print the grid. I'm confuse about using DataGrid or EnhancedGrid and when and how to use it. I want to take advantage of the plugin that dojox has. I actually found a script that uses this feature (see attachment).
But, now I'm stuck on how to make it work on my side. And for some reason my Clear button is not working anymore. Also, I wanted to hightlight the outline polygon a different color when the row in the grid gets selected. Any ideas on this?
I'm purposely omitting some parts. This is what I have so far:
<html>
    <head>
        <meta http-equiv="X-UA-Compatible" content="IE=edge">
        <meta name="viewport" content="initial-scale=1, maximum-scale=1, user-scalable=no">
        <title>Title</title>
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/dojox/grid/resources/Grid.css">
<link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
<style>
</style>
var .......center, zoom, grid, store;
require([
      "dojo/_base/connect",
        "dojo/dom",
        "dojo/parser",
        "dojo/on",
        "dojo/_base/array",
        "dojo/data/ItemFileReadStore",
        "dojo/data/ItemFileWriteStore",
        "esri/map",
        "esri/layers/FeatureLayer",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/symbols/SimpleMarkerSymbol",
        "esri/graphic",
        "esri/config",
        "esri/InfoTemplate",
        "esri/tasks/query",
        "esri/Color",
        "esri/tasks/FindTask",
        "esri/tasks/FindParameters",
        "dijit/layout/AccordionContainer",
        "dijit/layout/BorderContainer",
        "dijit/layout/ContentPane",
        "dijit/registry",
        "dijit/form/Button",
        "dijit/layout/TabContainer",
        "dojox/grid/DataGrid",
        "dojox/grid/EnhancedGrid",
        "dojox/grid/enhanced/plugins/Printer",
        "dojo/fx",
        "dojo/domReady!"
    ], function
                    connect, dom, parser, on, ..... arrayUtils, ItemFileReadStore, ItemFileWriteStore,
                    Map,....FeatureLayer, ArcGISTiledMapServiceLayer, ArcGISDynamicMapServiceLayer, SimpleFillSymbol, SimpleLineSymbol,
                    SimpleMarkerSymbol, ..... Graphic, .....esriConfig, InfoTemplate, ......
                    Query, Color, FindTask, FindParameters,..... AccordionContainer, BorderContainer, ContentPane, registry, Button, TabContainer,
                    DataGrid, EnhanceGrid, Printer, fx, domReady
        // call the parser to create the dijit layout dijits
        parser.parse();
map = new Map("map", {
sliderOrientation: "horizontal",
basemap: "topo",
center: [-93.745776, 32.513614],
zoom: 14,
dynaLayer1 = "http://......./MapServer/";
map.on("load", mapReady);
//variable REST service Shreveport as a layer
var layer = new ArcGISDynamicMapServiceLayer(dynaLayer1, {
opacity: 0.8 })
map.addLayer(layer);
//Create Find Task using the URL of the map service to search Caddo Parcels Parcels
        findTask = new FindTask("http://......./MapServer/");
        map.on("load", function () {
            //Create the find parameters
            findParams = new FindParameters();
            findParams.returnGeometry = true;
            findParams.layerIds = [12];
            findParams.searchFields = ["PARCELID"];
            findParams.outSpatialReference = map.spatialReference;
        function doFind() {
            //Set the search text to the value in the box
            findParams.searchText = dom.byId("searchText").value;
            findTask.execute(findParams, showResults);
        dom.byId('doParcelSearch').onclick = doFind;
        function showResults(results) {
            //This function works with an array of FindResult that the task returns
            map.graphics.clear();
            var symbol = new SimpleFillSymbol(
                    SimpleFillSymbol.STYLE_SOLID,
                    new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new Color([50, 25, 200]), 2),
                    new Color([98, 194, 204, 0.5])
            //create array of attributes
            var items = arrayUtils.map(results, function (result) {
                var graphic = result.feature;
                graphic.setSymbol(symbol);
                map.graphics.add(graphic);
                return result.feature.attributes;
            //Create data object to be used in store
            var data = {
                identifier: "PARCELID", //This field needs to have unique values
                label: "PARCELID", //Name field for display. Not pertinent to a grid but may be used elsewhere.
                items: items
            //Create data store and bind to grid.
            store = new ItemFileReadStore({
                data: data
            grid = registry.byId("grid");
            grid.setStore(store);
            grid.on("rowclick", onRowClickHandler);
            //Zoom back to the initial map extent
            map.centerAndZoom(center, zoom);
        //dojo Methods
        on(dojo.byID("printAll"), "click", function () {
            grid.printGrid({title: "Print Grid", cssFiles: []});
        //Zoom to the parcel when the user clicks a row
        function onRowClickHandler(evt) {
            var clickedTaxLotId = evt.grid.getItem(evt.rowIndex).PARCELID;
            var selectedTaxLot = arrayUtils.filter(map.graphics.graphics, function (graphic) {
                return ((graphic.attributes) && graphic.attributes.PARCELID === clickedTaxLotId);
            if (selectedTaxLot.length) {
                map.setExtent(selectedTaxLot[0].geometry.getExtent(), true);
        dom.byId('ClearSearch').onclick = clearMyGrid;
        function clearMyGrid()  {
            var emptyCells = { items: "" };
            var emptyStore = new dojo.data.ItemFileReadStore({data: emptyCells});
            grid.setStore(emptyStore);
</script>
</head>
<body class="claro">
    <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline', gutters:true" style="width:100%;height:100%;margin: 0;">
        <div id="header" data-dojo-type="dijit/layout/ContentPane" region="top">
            <div>
                <ul style="margin:20px">
                    <b>Title</b>
                    <div id="search"></div>
                </ul>
            </div>
        </div>
        <div data-dojo-type="dijit/layout/ContentPane" id="leftPane" region="left" splitter="true">
            <div data-dojo-type="dijit/layout/AccordionContainer" style="height: 300px;">
                    </div>
                </div>
                <div data-dojo-type="dijit/layout/ContentPane" title="Click for GEOGNO results" >
                    <input type="text" id="searchText" value="Input Parcel ID" />
                    <input type="button" value="Search" id="doParcelSearch"/>
                    <input type="button" value="Print All" id="printAll"/>
                    <input type="button" value="Clear" id="ClearSearch"/>
                    <table data-dojo-type="dojox.grid.DataGrid" jsid="grid" id="grid" >
                        <thead>
                        <th field="ParcelID">Parcel ID</th>
                        <th field="OWNER" >Owner</th>
                        <th field="ADDRESS">Address</th>
                        <th field="DESCRIPTION">Legal Description</th>
                        <th field="TAXSTATUS" width="100%">Tax Status</th>
                        </thead>
                    </table>
                </div>
            </div>
        </div>
        <div id="map" data-dojo-type="dijit/layout/ContentPane"
             data-dojo-props="region:'center'">
            <div id="HomeButton"></div>
            <div style="position:absolute; right:50px; top:10px; z-Index:999;">
                <div data-dojo-type="dijit/TitlePane"
                     data-dojo-props="title:'Switch Basemap', closable:false, open:false">
                    <div data-dojo-type="dijit/layout/ContentPane" style="width:380px; height:280px; overflow:auto;">
                        <div id="basemapGallery"></div>
                    </div>
                </div>
            </div>
        </div>
</body>
</html>
