I am using Nliu's TC widget in my application, it is great. When I used the identifyTask to get the info for the visible layers, I could only identify layers from one map service. I used the code as following.
identifyParameters.layerIds = dynamicMapServiceLayer.visibleLayers;
It seems I have to manually assigned which map service I am going to use. I have multiple map services show in the TOC. Is there a way could know that which map service the visible layer belong to?
Zhujing
Take a look at the code in this post. It contains multiple map services that are utilized in the identifyTask.
Ken,
I saw the this sample code before and tried it.
I could get result back from this code for the layers:
var layers = dojo.map(map.layerIds, function (layerId) {
return map.getLayer(layerId);
But I run into error for this code , no result for layer, the layer is undefined. Do you know why is that?
layers = dojo.filter(layers, function (layer) {
if (layer.visibleLayers[0] !== -1) {
return layer.getImageUrl && layer.visible
Zhujing
>>> Ken Buja <geonet@esri.com> 11/5/2014 2:14 PM >>>
Ken Buja replied to the discussion
"How to know which dynamc map service the visible layer cam from in Nliu's TC widget"
To view the discussion, visit: https://community.esri.com/message/435667?et=watches.email.thread#435667
Can you post your code? This sample is working correctly here.
I have a big project, here is my identfy.js file It could only identify one map service.
var map_click_handle_Identify; //event procedure for map-onClick
var map_identify_first_time = true;
var mapClickX = 0;
var mapClickY = 0;
var identifyTreeDisplayData = [];
var selectedFeature;
var myFeatureScroll;
var myIdentifyScroll;
//Identify tool
function initIdentifyTool() {
//currently nothing needs to be initialized
function setActiveToolIdentify() {
//attach identify tool to map click event
map_click_handle_Identify = dojo.connect(map, "onClick", doIdentify);
map.setMapCursor("crosshair");
function ShowIdentifyPanel() {
$('#identifywindow').dialog({
title: "Map Identify Tool",
show: { effect: "fade", duration: 250 },
hide: ,
modal: false,
//position: ,
height: 320,
width: 470,
resizable: true,
closeOnEscape: false,
close: function () { },
resize: function (event, ui) {
var fpwidth = $("#identifywindow_featurepanel_wrapper").width();
$("#identifywindow_attributepanel").css({ "left": String(fpwidth + 10) + "px", "width": "auto" });
//update iscroll
$("#identifywindow_featurepanel").css({ "min-height": String($("#identifywindow_featurepanel_wrapper").height()) + "px" });
myFeatureScroll.refresh();
$("#scroller").css({ "min-height": String($("#wrapper").height() + 3) + "px" });
myIdentifyScroll.refresh();
if (map_identify_first_time) {
//set window position on first time only
$('#identifywindow').dialog({ position: { my: "right top", at: "right-25 top+100", collision: "flipfit"} });
map_identify_first_time = false;
//capture map click event - select parcel
var lastCalledIdentifyTimestamp = new Date();
function doIdentify(evt) {
var thisCallTimestamp = new Date();
dmsg(thisCallTimestamp - lastCalledIdentifyTimestamp);
if ((thisCallTimestamp - lastCalledIdentifyTimestamp) < 500) { //on mobile, screen touch may fire up twice - use timer to eliminate the second request just in case
lastCalledIdentifyTimestamp = thisCallTimestamp;
return;
mapClickX = evt.mapPoint.x;
mapClickY = evt.mapPoint.y;
if (cfg_multiLayerIdentifyToolEnabled == 1 || cfg_featureToolEnabled == 1) {
dmsg('5.1 on map clicked');
showLoading();
map.graphics.clear();
if (cfg_multiLayerIdentifyToolEnabled == 1) {
require(["esri/tasks/IdentifyTask", "esri/tasks/IdentifyParameters"], function (IdentifyTask, IdentifyParameters) {
ShowIdentifyPanel();
//alert('not implemented');
if (map.getScale() > cfg_identifyMinScale) {
jsapimessage("Please zoom in closer.");
hideLoading();
return;
var identifyParameters = new IdentifyParameters();
identifyParameters.geometry = evt.mapPoint;
identifyParameters.returnGeometry = true;
identifyParameters.mapExtent = map.extent;
identifyParameters.height = map.height;
identifyParameters.width = map.width;
identifyParameters.spatialReference = map.spatialReference;
//identifyParameters.layerOption = IdentifyParameters.LAYER_OPTION_VISIBLE; //this will take default visible layers from MXD, ignoring current state in the TOC control
identifyParameters.layerOption = IdentifyParameters.LAYER_OPTION_ALL;
identifyParameters.tolerance = cfg_identifyTolerance;
if (cfg_tocEnabled == 1) {
//if toc control is enabled, the default visibility may have changed, the option LAYER_OPTION_VISIBLE may not represent currrent visible layers
//identifyParameters.layerIds = map.getLayer("dynamicmap").visibleLayers;
var identifyServer = cfg_identifyServerURL.checkAppendToken();
var identifyTask = new IdentifyTask(identifyServer);
identifyTask.execute(identifyParameters, function (idResults) { processIdentifyResult(idResults, evt); }, identifyError);
} else if (cfg_featureToolEnabled == 1) {
require(["esri/tasks/QueryTask", "esri/tasks/query", "esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol"], function (QueryTask, Query, SimpleFillSymbol, SimpleLineSymbol) {
var queryServer = (cfg_queryServerURL + "/" + kv[cfg_featureToolLayerName.toUpperCase()].toString()).checkAppendToken();
var queryTask = new QueryTask(queryServer);
var query = new Query();
query.returnGeometry = true;
query.outFields = ["*"];
query.geometry = evt.mapPoint;
query.spatialRelationship = Query.SPATIAL_REL_INTERSECTS;
queryTask.execute(query, function (featureSet) {
if (featureSet.features.length == 0) {
jsapimessage("Nothing is selected.");
hideLoading();
} else {
//get feature
var graphic = featureSet.features[0];
//setup graphic layer and symbol
var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_NULL, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color(), 4), new dojo.Color());
//add graphic to map
graphic.setSymbol(symbol);
map.graphics.add(graphic);
//get extent
var ext
var geometry = graphic.geometry;
var ext = getExtentFromGeometry(geometry);
var featurekey = graphic.attributes[cfg_featureToolLayerKeyField];
executeFeatureFunction(featurekey);
hideLoading();
dmsg('5.2 on map clicked done');
} else {
alert("Identify tool and/or feature tool has not been configured for this application.");
function identifyError(error) {
hideLoading();
alert('There was an error executing identify task.\n' + error.get_message());
function processIdentifyResult(idResults, evt) {
//array variable to hold all known layer names
var layerNameList = [];
//reset result object, create root node
identifyTreeDisplayData.length = 0;
identifyTreeDisplayData.push({ id: "Identify Layers", name: "Layer Name", features: "" })
//clear existing content in attribute pabel
$("#identifywindow_featurepanel").html("");
//check if identify result contains any feature
if (idResults.length == 0) {
No features found.
");hideLoading();
return;
for (var i = 0, il = idResults.length; i < il; i++) {
idResult = idResults;
if (layerNameList.length == 0 || layerNameList.indexOf(idResult.layerName) == -1) { //check if we need to insert a new layer node
layerNameList.push(idResult.layerName); //add this layer to list of known layer
identifyTreeDisplayData.push({ id: idResult.layerName, name: idResult.layerName, features: "", parent: "Identify Layers" }); //insert layer node into identifyTreeDisplayData
identifyTreeDisplayData.push(); //insert feature into identifyTreeDisplayData
require([
"dojo/_base/window",
"dojo/store/Memory",
"dijit/tree/ObjectStoreModel",
"dijit/Tree",
"dojo/domReady!"],
function (win, Memory, ObjectStoreModel, Tree) {
var identifyStore = new Memory({
data: identifyTreeDisplayData,
getChildren: function (object) {
return this.query({ parent: object.id }); //return all elements in which element.parent = this-object.id
var identifyModel = new ObjectStoreModel(
//clear out existing identify tree object
var oldtree = dijit.byId('identifyTree');
if (oldtree) {
oldtree.destroy();
var identifyTree = new Tree(,
autoExpand: true,
onClick: identifyTreeOnClick,
style: "overflow: hidden;"
identifyTree.placeAt("identifywindow_featurepanel").startup();
identifyTree.on("load", function () {
if (myFeatureScroll != null) {
} else {
myFeatureScroll = new iScroll('identifywindow_featurepanel_wrapper', { hScrollbar: false, hideScrollbar: false });
// Automaticalyl select the first feature (node #3 in the tree) --> Root Node \ First Layer Node \ First Feature Node
identifyTree.onLoadDeferred.then(function () {
if (identifyTreeDisplayData.length > 2) {
identifyTree.set("path", [identifyTreeDisplayData[0].id, identifyTreeDisplayData[1].id, identifyTreeDisplayData[2].id]);
var selectedNode = identifyTreeDisplayData[2];
identifyTreeOnClick(selectedNode);
hideLoading();
function identifyTreeOnClick(item) {
if (!item.root) {
$("#identifywindow_attributepanel").empty();
if (item.features !== "") { //check to make sure this is a feature node, not a layer node
selectedFeature = item;
var content = "";
content += "
" + item.id + ""
//header row closing tags
content += "
content += "
content += "
//attribute fields
dojo.forEach(LayersFieldName, function (layer) {
if (layer.layerName === item.parent) {
dojo.forEach(layer.layerFields, function (field) {
if ($.inArray(field.name.toUpperCase(), cfg_identifyFieldToHide) == -1 && $.inArray(field.alias.toUpperCase(), cfg_identifyFieldToHide) == -1) {
var fv = item.features.attributes[field.alias];
if (fv.toUpperCase().startsWith('HTTP://') || fv.toUpperCase().startsWith('HTTPS://')) {
fv = String.format("
",fv)
content += "
content += "
" + field.name + "
content += "
" + fv + "
content += "
content += "
//end table
content += ""; //scroller
content += ""; //wrapper
//end table
//apply result html to attribute panel
$("#identifywindow_attributepanel").html(content);
myIdentifyScroll = new iScroll('wrapper', );
function hyperLinkField(item, field) {
var content = item.features.attributes[field.alias];
dojo.forEach(ConfigLayersWithAttachment, function (layerWithAttachment) {
if (item.parent == layerWithAttachment.layerName && field.name == layerWithAttachment.fieldName) {
content = "" + content + "";
return content;
function zoomToIdentifyFeature() {
var layerID = selectedFeature.layerId;
if (layerID == undefined) return;
var objectID = selectedFeature.features.attributes.OBJECTID;
//initialize query task
require(["esri/tasks/QueryTask", "esri/tasks/query"], function (QueryTask, Query) {
var queryTask = new QueryTask((cfg_dynamicMapLayerURL + "/" + layerID.toString()).checkAppendToken());
var query = Query();
query.outSpatialReference = map.spatialReference;
query.where = "OBJECTID ='" + objectID + "'";
queryTask.execute(query, showIdentifyResult);
function showIdentifyResult(featureSet) {
var resultFeatures = featureSet.features;
require(["esri/symbols/SimpleFillSymbol", "esri/symbols/SimpleLineSymbol", "esri/symbols/SimpleMarkerSymbol", ], function (SimpleFillSymbol, SimpleLineSymbol, SimpleMarkerSymbol) {
var myFillSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color(), 4), new dojo.Color());
var myLineSymbol = new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color(), 4);
var myMarkerSymbol = new SimpleMarkerSymbol(SimpleMarkerSymbol.STYLE_CIRCLE, 10, new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID, new dojo.Color(), 1), new dojo.Color());
dojo.forEach(resultFeatures, function (feature) {
TempGraphic = feature;
switch (feature.geometry.type) {
case "point":
case "multipoint":
TempGraphic.setSymbol(myMarkerSymbol);
agsjsZoomToLocationXY(feature.geometry.x, feature.geometry.y, cfg_ds_point_zoom_width);
break;
case "line":
case "polyline":
TempGraphic.setSymbol(myLineSymbol);
var extent = feature.geometry.getExtent().expand(cfg_ds_polygon_zoom_factor);
break;
default:
TempGraphic.setSymbol(myFillSymbol);
break;
map.setExtent(extent, true);
map.graphics.add(TempGraphic);
return;
>>> Ken Buja <geonet@esri.com> 11/5/2014 2:49 PM >>>
To view the discussion, visit: https://community.esri.com/message/435669?et=watches.email.thread#435669
if i add this code into function doIdentify(evt)
}); //I could get result back for layers
}); //But I run into error for this code , no result for layer, the layer is undefined.
I know nothing about the widget, but I can think of a possible solution/walkaround.
1. Create an Array of all layers (IDs) used by the widgets.
2. When needed, loop through the array, and find what is visible (layer.visible || layer.visibleAtMapScale);
