Javascript for geocoding the address and buffer around it.
3129
5
10-29-2014 05:58 AM
ManjariGoyal
I have a script which geocode an address and buffer that address by 1, 5 and 10 mile radius. The problem I am having is that the address on the map shows 4 different points.not sure what's causing it. I am attaching a screen shot of the output. Please let me know how to fix this issue.
<!doctype html>
<html lang="en">
  <head>
    <meta charset="utf-8">
    <meta http-equiv="X-UA-Compatible" content="IE=7,IE=9" />
    <meta name="viewport" content="initial-scale=1, maximum-scale=1,user-scalable=no"/>
    <title>Find Address</title>
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/dojo/dijit/themes/tundra/tundra.css" />
    <link rel="stylesheet" type="text/css" href="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/js/esri/css/esri.css" />
    <style>
      html, body { height: 100%; width: 100%; margin: 0; padding: 0; }
      h3 { margin: 0 0 5px 0; border-bottom: 1px solid #444; }
      .shadow {
        -moz-box-shadow: 0 0 5px #888;
        -webkit-box-shadow: 0 0 5px #888;
      #map{ margin: 0; padding: 0; }
      #feedback {
        background: #fff;
        bottom: 30px;
        color: #444;
        position: absolute;
        font-family: arial;
        height: 80px;
        left: 30px;
        margin: 5px;
        padding: 10px;
        width: 300px;
        z-index: 40;
    </style>
    <script>var dojoConfig = { parseOnLoad: true };</script>
    <script src="http://serverapi.arcgisonline.com/jsapi/arcgis/3.2/"></script>
    <script>
      dojo.require("dijit.layout.BorderContainer");
      dojo.require("dijit.layout.ContentPane");
      dojo.require("dijit.form.Button");
      dojo.require("esri.arcgis.utils");
      dojo.require("esri.map");
      dojo.require("esri.tasks.locator");
      var map, locator;
      function init() {
        var webmapId = "1234567asdfg";
        //create map
        var mapDeferred = esri.arcgis.utils.createMap(webmapId, "map", {
          mapOptions: { slider: false }
        locator = new esri.tasks.Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
        dojo.connect(dijit.byId("locate"), "onClick", function() {
          map.graphics.clear();
          var address = dojo.byId("address").value;
          console.log("address: ", address);
          if ( ! address ) {
            alert("Please enter an address to geocode.");
            return;
          locator.outSpatialReference = map.spatialReference;
          var geocode = locator.addressToLocations({
            address: { "SingleLine": address },
            outFields: ["*"]
          geocode.then(function(results) {
            console.log("got results: ", results);
            // add the results to the map
            dojo.forEach(results, function(r) {
              map.graphics.add(new esri.Graphic(
                r.location, new esri.symbol.SimpleMarkerSymbol(), r.attributes
            console.log("added graphics...now buffer the first one");
            bufferLocation(results[0]);
          }, function(error) {
            console.log("geocode failed: ", error);
        mapDeferred.addCallback(function (response) {
          map = response.map;
          dojo.connect(dijit.byId("map"), "resize", map, map.resize);
      function bufferLocation(place) {
        var bufferParams = new esri.tasks.BufferParameters();
        bufferParams.geometries = [ place.location ];
        bufferParams.distances = [ 1, 5, 10 ]; // miles
        bufferParams.unit = esri.tasks.GeometryService.UNIT_STATUTE_MILE;
bufferParams.outSpatialReference = map.spatialReference;
        var gs = new esri.tasks.GeometryService("http://networkgis.corp.sprint.com/networkags/rest/services/Utilities/Geometry/GeometryServer");
        var buffer = gs.buffer(bufferParams);
        buffer.then(function(buffers) {
          console.log("got buffers: ", buffers);
          dojo.forEach(buffers, function(b) {
              b, new esri.symbol.SimpleFillSymbol()
          console.log("error doing buffer...", error);
      dojo.ready(init);
    </script>
  </head>
  <body class="tundra">
    <div data-dojo-type="dijit.layout.BorderContainer"
         data-dojo-props="design:'headline',gutters:false"
         style="width: 100%; height: 100%; margin: 0;">
      <div id="map"
           data-dojo-type="dijit.layout.ContentPane"
           data-dojo-props="region:'center'">
        <div id="feedback" class="shadow">
          <h3>Locate and buffer an address</h3>
          <div id="info">
            <input type="text" id="address" value="6360 Sprint Parkway Overland Park KS">
            <button dojotype="dijit.form.Button" id="locate">Locate</button>
          </div>
        </div>
      </div>
    </div>
  </body>
</html>
RobertScheitlin__GISP
Hi Manjari,
  Just to add to Jake's correct answer the geocode service from arcgis.com also returns 100% matches for just the street name and the city being correctly matched so to further refine the geocode results you can filter then by candidate.attributes.AddNum.
This would ignore the 100% matches of just:
  1. Sprint Pky, Overland Park, Kansas, 66251
  2. Sprint Pky, Overland Park, Kansas, 66211
  3. Overland Park, Kansas
Here is an example:
        geocode.then(function (results) {
          dojo.forEach(results, function (r) {
            if(r.score >= 90 && r.attributes.AddNum !== ""){
        }, function (error) {
JakeSkinner
Esri Esteemed Contributor
Hi Manjari,
This is occurring because there is more than one address returned when you perform the geocode.  You can limit this to the first result if the matching score is high enough.  For example, try the following:
    var candidate = results[0];
    if(candidate.score > 90){
          candidate.location, new esri.symbol.SimpleMarkerSymbol(), candidate.attributes
    bufferLocation(candidate);
ManjariGoyal
Thanks Jake for the help.
Hi Manjari,
Here is an example:
ManjariGoyal
Thanks Robert for ur help
Manjari,
  Also I would really recommend that you move away from the Legacy coding style and switch to AMD.
Here is your app using 3.11 and AMD.
<!DOCTYPE html>
<html>
<head>
  <meta http-equiv="Content-Type" content="text/html;charset=utf-8" >
  <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
  <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
  <script src="http://js.arcgis.com/3.11/"></script>
  <style>
    html,
    body {
      height: 100%;
      width: 100%;
      margin: 0;
      padding: 0;
    h3 {
      margin: 0 0 5px 0;
    .shadow {
    #map {
      margin: 0;
      padding: 0;
      height: 100%;
      width: 100%;
    #feedback {
      background: #fff;
      bottom: 30px;
      color: #444;
      position: absolute;
      font-family: arial;
      height: 80px;
      left: 30px;
      margin: 5px;
      padding: 10px;
      width: 300px;
      z-index: 40;
  </style>
  <script>
    var map, locator;
    require([
      "esri/map",
      "esri/tasks/locator",
      "esri/arcgis/utils",
      "dojo/parser",
      "esri/tasks/BufferParameters",
      "esri/tasks/GeometryService",
      "dijit/registry",
      "dojo/on",
      "dijit/form/Button",
      "dijit/layout/BorderContainer",
      "dijit/layout/ContentPane",
      "dojo/domReady!"
    ], function(
      Map,
      Locator,
      arcgisUtils,
      parser,
      BufferParameters,
      GeometryService,
      registry,
      on,
      Button,
      BorderContainer,
      ContentPane
        parser.parse();
        //create map
        arcgisUtils.createMap("7a7a9694c9b241aba171fa11fc9b0448", "map", {mapOptions: {slider: false}}).then(function(response){
          map = response.map;
          locator = new Locator("http://geocode.arcgis.com/arcgis/rest/services/World/GeocodeServer");
            var bufferParams = new BufferParameters();
            bufferParams.geometries = [place.location];
            bufferParams.distances = [1, 5, 10]; // miles
            var gs = new GeometryService("http://gislap183:6080/arcgis/rest/services/Utilities/Geometry/GeometryServer");
            buffer.then(function (buffers) {
              dojo.forEach(buffers, function (b) {
          registry.byId("locate").on("click",  function () {
            if (!address) {
              return;
              address: {
              outFields: ["*"]
  </script>
</head>
<body class="claro">
  <div data-dojo-type="dijit/layout/BorderContainer" data-dojo-props="design:'headline',gutters:false" style="width: 100%; height: 100%; margin: 0;">
    <div id="map" data-dojo-type="dijit/layout/ContentPane" data-dojo-props="region:'center'">
        <div id="info">
          <button id="locate" data-dojo-type="dijit/form/Button" type="button">Locate</button>
        </div>
      </div>
    </div>
  </div>
</body>
</html>
