Authorization and install issues. Please Help.
3922
10-29-2014 06:30 PM
MistyCalhoun
Im trying to install student edition software, I get the authorization, but when I go to open arcmaps it says its not authorized... Please help.Authorization
RebeccaStrauch__GISP
Tthis looks like an old thread that popped to the top for some reason (??)....basically the same question as Authorization issues for ArcGIS 10.1    So, I'll give same response....but others may have better info.
Aare you getting any specific errors?  Seems there are a few others that have had similar questions like this.  This is the only one that I've seen  an answer
Error 7109 - ArcGIS Education trial Authorization   Which may not be your issue, but Stuart's advice is still pretty accurate.
V Stuart Foote has a blog Query shortcut to find all prior ArcGIS for Desktop Installation, Configuration posts   with a link  to help search for license issues.  That us his I found the link above.  You may want to look thru that list to see if anything can help you situation, if the above doesn't.
