LAS custom GP tools - processing extent
3584
10-27-2014 01:58 AM
PaulLohr
Has anyone been able to make the processing extent work for the LAS to LAS tool? I have not been able to make it work. The outputted LAS files end up with the same extent as the original LAS files rather than what is set in the processing extent. My layer used as the basis for the processing extent is even in the same projection as the LAS files.
LAS custom GP tools come within a toolbox that was published by ESRI.
Processing extent is an environment variable that is supposed to be supported by the LAS to LAS tool.
Below is a link to the toolbox.
http://www.arcgis.com/home/item.html?id=d19c05deaf42447c9b4fc68fc4bb9c7a
I am using ArcGIS Desktop 10.2.2.3552.
Thank you for any help,
Paul Lohr
Paul Lohr
Lohr Geospatial Services, Inc.
