Adding zeros or numbers in a Field
10408
26
10-24-2014 01:32 PM
MichelleCouden1
I have two fields that I need to concatenate together but I need to add zeros so one said has 4 digits and the other side has 2 digits. Both separated with a hypen. For Example, 0024-14.
This is the code I have written am I close???
Left([ACONTROL], 4, "-") & Right([ASECTION], 2)
So, it would be field ACONTROL with 4 digits and ASECTION with 2 digits.
DanPatterson_Retired
OMG  you might be using an older version of Arcmap and not Python 2.7 or above
try this
"00{0}-0{1}".format(int(!ACONTROL!)),int(!ASECTION!))
Notice the {0} instead of {} and {1} instead of {}
grief...if that is it...note to both of ourselves...arcmap and python version are needed
In python
>>> for ACONTROL in [1,10,24]:
...  for ASECTION in [2,10,20]:
...   print"00{}-0{}".format(ACONTROL,ASECTION)
001-02
001-010
001-020
0010-02
0010-010
0010-020
0024-02
0024-010
0024-020
or do you want the first condition to read 0001-02 (line 5) and the one on line 11 to  read 0024-002?
MichelleCouden1
I can write this code in Field calculator right??
for this specific case use
print"00{}-0{}".format(!ACONTROL!,!ASECTION!)
using the python parser
as I indicated there are other options depending on all your possible conditions
BruceNielsen
I think zfill would be a little more flexible:
     print "%s-%s" % (!ACONTROL!.zfill(4), !ASECTION!.zfill(2))
That will automatically pad the input with the correct number of zeros.
MichelleCouden1
I'm thinking I have to have it as a shapefile because I keep getting errors for the code. It keeps saying invalid syntax. I'm typing them as is. Do I have to put something in front of print??
I am typing in field calculator box
this assumes that you are using the python parser in the field calculator and you have two fields named as above, capitalized etc and in python fields are enclosed in ! ! 's
MichelleCouden1
Typing it exactly like you have it. I am getting a ValueError : zero length field name in format. I have those field names so I'm not sure why it doesn't like it.
you added a text field...correct...and are doing the calculation there.  a screen grab of your table with the field calculator would go a long way to shortening this thread
MichelleCouden1
Screen1.jpgScreen2.jpgYes! I just looked to double check. I'll attach 2 screen shots. One of the table one of the field calculator. Let me know if you need anything else. I am going to keep trying to figure it out.
