Save printTask output as image, add download button
3076
9
10-24-2014 02:33 PM
TracySchloss
Honored Contributor
I had this crazy idea today that I could use the print task to do a sort of screen scrape of my map and save it into a floating pane.  This would allow the user to keep a snapshot of what the screen looked like at a point in time.  Now I would like to allow the user to have a 'Download' button that appears at the bottom of the image so that it prompts them where to save it.
I know browsers will let them save an image with right click, but I'd like to make it more user friendly.  At the moment it only lets them open the image in a new tab, which is the default behavior from the printTask in the first place.  I'm trying to pretty it up a bit.
http://jsfiddle.net/schlot/s2vzsL84/
RobertScheitlin__GISP
Tracy,
  OK, here is the updated code for the .net portion. You are going to have to modify it to handle your pages ability to export as jpg, because right now you have it hard coded to handle png only:
<%@ WebHandler Language="C#" class="img" %>
using System;
using System.Web;
using System.Net;
public class img : IHttpHandler
    public void ProcessRequest(HttpContext context)
        String content = "no data";
        String filename = "MyFile";
        if (context.Request["report"] != null)
            try
                content = context.Request["report"].ToString();
            catch
        if (context.Request["filename"] != null)
            try
                filename = context.Request["filename"].ToString() + "_" + DateTime.Now.ToString("MMddyyyy");
            catch
        byte[] imageData;
        using (WebClient client = new WebClient())
            imageData = client.DownloadData(context.Request["report"].ToString());
        context.Response.OutputStream.Write(imageData, 0, imageData.Length);
        context.Response.ContentType = "image/png";
        context.Response.AddHeader("content-disposition", "attachment;filename=" + filename + ".png");
    public bool IsReusable
        get
            return false;
Tracy,
  The download attribute in the anchor tag is the best client side option there is but the image is dealt with differently based on the browser. In Chrome you actually get the image to download to chromes default download location (on save dialog), in Firefox the image is just opened in the browser window (no save dialog or actual download). The only cross browser solution is serverside technology. You can have an .net or php page that would set the headers content to image/octet-stream
TracySchloss
Honored Contributor
I had to do something like that to allow the user to download a table as CSV.  For that project, I found an example with instructions that worked without having to edit the C# code.  I don't know that language at all.  I've attempted to modify my CSV project code to work for images, but I don't know c# and I don't know where to insert the proper headers.
If you happen to know C#, here's my attempt to modify the code I used before. I have a form that has all it's input hidden to act as placeholders.
<div id="downloadForm" data-dojo-type="dijit/form/Form" method="post" action="webservices/img.ashx" target="_blank">
    <input type="hidden" name="report" id="reportinput" value="" />
    <input  type="hidden" name="filename"  id="filename" value="" />
</div>
function submitPrint() {
    var deferred;
    var printParams = new PrintParameters();
    printParams.map = map0;
    var status = dom.byId("printStatus");
    status.innerHTML = "Generating ...";
  var template = new PrintTemplate();
  template.format = "png32";
  template.layout="MAP_ONLY";
  template.showAttribution = false;
  template.preserveScale = false;
  template.exportOptions = {
  width: 500,
  height: 400,
  dpi: 96
    printParams.template = template;
    var printTask = new PrintTask(printServiceUrl,printParams);
    deferred = printTask.execute(printParams);
       deferred.addCallback(function (response){
        var d = new Date();
        var dateTime =  d.getTime();
        var outputUrl = response.url + '?time=' + dateTime;
        status.innerHTML = "";
        var newDiv = domConstruct.create("div", null, registry.byId('centerPane').domNode, "last");
        var imageLink = "<a  href="+ outputUrl+ " target=_blank ;'>Open Image</a> ";
        var imageLink2 = "<a  href="+ outputUrl+ " download='screenCapture.png'>Download</a>";
          var   saveButton = new Button({
          label: "Save Image",
          onClick: function(){
            saveImage(response.url);
          },"btnSave");
        var pFloatingPane = new FloatingPane({
             title: "A floating pane",
             content: "<img src='"+response.url+"' />" +"</br>" ,
             resizable: true, dockable: true,
             style: "position:absolute;top:50;left:50;width:500px;height:450px; z-index: 95;visibility:visible;"
          }, newDiv);
          pFloatingPane.addChild(saveButton);
          pFloatingPane.startup();
    deferred.addErrback(function (error) {
        console.log("Print Task Error = " + error);
       status.innerHTML = "Error generating printout, try again";
function saveImage(inputData) {
    var f = registry.byId("downloadForm");
    dom.byId("reportinput").value = inputData;
//   var outFileName = setOutName(gridName);
    dom.byId("filename").value = "imageOutput";
//    console.log(inputData);
    f.submit();
C# code
using System;
using System.Web;
public class img : IHttpHandler {
public void ProcessRequest (HttpContext context) {
        try
        catch
        try
        catch
    context.Response.AddHeader("content-disposition","attachment;filename="+filename+".png");
    context.Response.Write(content);
public bool IsReusable {
    get {
        return false;
Tracy,
    So just change this line:
context.Response.ContentType = "image/octet-stream";
TracySchloss
Honored Contributor
It just opens my img.ashx code in the browser.  I'm not sure I'm feeding in the right input into the saveImage function.  It's the url to the image location, not an image object.
Tracy,
using System;
using System.Web;
using System.Net;
            try
            catch
            try
            catch
        byte[] imageData;
        get
            return false;
TracySchloss
Honored Contributor
Since I only have one option in the printTask, png, I figured it made sense to hard code it for png for saving.  It still just opens the img.ashx file as a separate tab.
Tracy,
  OK the solution seems to be this (change target):
<div id="downloadForm" data-dojo-type="dijit/form/Form" method="post" action="webservices/img.ashx" target="_self">
TracySchloss
Honored Contributor
I guess I can't mark more than one thread as correct, so I'll just do the C# script since that's the bulk of what people need.  I was just running the script from the development environment.  I needed to run it from the server URL in order to get it to work.
Tracy,
   Glad you got it working.
That is correct but you can use the actions menu on the thread and choose "mark as helpful" this will give other readers the indication that that particular thread was helpful in answering the question.
