Problem opening PDF created with secure data and print services
2562
10-21-2014 09:56 AM
TracySchloss
Honored Contributor
I know there are several threads out there for printing secure services, but I haven't found one yet that describes what I'm experiencing.  I have a created a secure print service following the instructions in the help.  We have secured it.  In the code, there is a call to that services as
    var printTask = new esri.tasks.PrintTask(printServiceUrl,printParams);
    deferred = printTask.execute(printParams);
       deferred.addCallback(function (response){
        var d = new Date();
        var dateTime =  d.getTime();
        var outputUrl = response.url + '?time=' + dateTime;
        status.innerHTML = "";
        var select = dijit.byId("templateSelect");
        var selectOptions = select.getOptions();
        select.set("value", "Choose Print Format");
        window.open(outputUrl,"_blank");
A PDF is getting created, we can see it in the output directory.  However we can't open it, we get an error 499, indicating that it needs a token.  If I look back through the webmap_as_JSON call to the print services, I can see the token that's generated.  If I append it as an argument to the end of my PDF that's created, then I can view the PDF.
My question is, is there a way to capture the token programmatically so I can pass it to the PDF?
Tags (3)
