Fetching values of fields in a feature layer
5838
6
10-21-2014 09:05 AM
IsraAlhamood
I'm trying to set the content of an infoTemplate of a feature layer depending on the field value(${OBJECTID})
for example:
if the ${OBJECTID} = 1 then infoTemplate.setContent("Something")
if the ${OBJECTID} = 2 then infoTemplate.setContent("Something2")
but whenever I do it it keeps giving me an error.
Any idea on how can I fetch the field value from the feature selected?
KenBuja
MVP Esteemed Contributor
This is a modification of an existing sample. When you hover over Aiken county, you'll see the content change. The modification is in the countiesGraphicsLayer "mouse_over" event
<!DOCTYPE html>
<html>
  <head>
    <!--The viewport meta tag is used to improve the presentation and behavior of the samples
      on iOS devices-->
    <title>QueryTask with geometry, results as an InfoWindow onHover</title>
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/dijit/themes/claro/claro.css">
    <link rel="stylesheet" href="http://js.arcgis.com/3.11/esri/css/esri.css">
    <script src="http://js.arcgis.com/3.11/"></script>
    <script>
      var map;
      require([
        "esri/map",
        "esri/graphic",
        "esri/InfoTemplate",
        "esri/SpatialReference",
        "esri/geometry/Extent",
        "esri/layers/GraphicsLayer",
        "esri/symbols/SimpleFillSymbol",
        "esri/symbols/SimpleLineSymbol",
        "esri/tasks/query",
        "esri/tasks/QueryTask",
        "esri/Color",
        "dojo/domReady!"
        function (
          Map, Graphic, InfoTemplate, SpatialReference, Extent, GraphicsLayer,
          SimpleFillSymbol, SimpleLineSymbol, Query, QueryTask, Color
          map = new Map("mapDiv", {
              basemap: "streets",
              center: [-80.94, 33.646],
              zoom: 8
          map.on("load", setUpQuery);
          function setUpQuery () {
            var queryTask = new QueryTask("http://sampleserver1.arcgisonline.com/ArcGIS/rest/services/Demographics/ESRI_Census_USA/MapServer/3");
            //build query filter
            var query = new Query();
            query.returnGeometry = true;
            query.outFields = ["NAME", "POP2000", "POP2007", "POP00_SQMI", "POP07_SQMI"];
            query.outSpatialReference = { "wkid": 102100 };
            query.where = "STATE_NAME = 'South Carolina'";
            var infoTemplate = new InfoTemplate();
            var content = "<b>2000 Population: </b>${POP2000}<br/>" +
                          "<b>2000 Population per Sq. Mi.: </b>${POP00_SQMI}<br/>" +
                          "<b>2007 Population: </b>${POP2007}<br/>" +
                          "<b>2007 Population per Sq. Mi.: </b>${POP07_SQMI}";
            infoTemplate.setTitle("${NAME}");
            infoTemplate.setContent(content);
            map.infoWindow.resize(245, 125);
            //Can listen for complete event to process results
            //or can use the callback option in the queryTask.execute method.
            queryTask.on("complete", function (event) {
              map.graphics.clear();
              var highlightSymbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
                new SimpleLineSymbol(SimpleLineSymbol.STYLE_SOLID,
                  new Color([255, 0, 0]), 3), new Color([125, 125, 125, 0.35]));
              var symbol = new SimpleFillSymbol(SimpleFillSymbol.STYLE_SOLID,
                  new Color([255, 255, 255, 0.35]), 1), new Color([125, 125, 125, 0.35]));
              var features = event.featureSet.features;
              var countiesGraphicsLayer = new GraphicsLayer();
              //QueryTask returns a featureSet.
              //Loop through features in the featureSet and add them to the map.
              var featureCount = features.length;
              for (var i = 0; i < featureCount; i++) {
                //Get the current feature from the featureSet.
                var graphic = features; //Feature is a graphic
                graphic.setSymbol(symbol);
                graphic.setInfoTemplate(infoTemplate);
                countiesGraphicsLayer.add(graphic);
              map.addLayer(countiesGraphicsLayer);
              map.graphics.enableMouseEvents();
              //listen for when the mouse-over event fires on the countiesGraphicsLayer
              //when fired, create a new graphic with the geometry from event.graphic
              //and add it to the maps graphics layer
              countiesGraphicsLayer.on("mouse-over",function (event) {
                map.graphics.clear();  //use the maps graphics layer as the highlight layer
                var graphic = event.graphic;
                if (graphic.attributes.NAME === "Aiken") {
                   map.infoWindow.setContent("Found it");
                } else {
                   map.infoWindow.setContent(graphic.getContent());
                map.infoWindow.setTitle(graphic.getTitle());
                var highlightGraphic = new Graphic(graphic.geometry, highlightSymbol);
                map.graphics.add(highlightGraphic);
                map.infoWindow.show(event.screenPoint,
                  map.getInfoWindowAnchor(event.screenPoint));
              //listen for when map.graphics mouse-out event is fired
              //and then clear the highlight graphic
              //and hide the info window
              map.graphics.on("mouse-out", function () {
                map.infoWindow.hide();
            queryTask.execute(query);
    </script>
  </head>
  <body class="claro">
    Hover over a county in South Carolina to get more information.
    <div id="mapDiv" style="width:900px; height:600px; border:1px solid #000;"></div>
  </body>
</html>
KenBuja
You should be able to do this using the syntax
if (feature.attributes.OBJECTID === 1) {
} else if (feature.attributes.OBJECTID === 2 {
} else ...
You could also use switch instead of if if you have many conditions. Take a look at this post showing some different ways of using them.
IsraAlhamood
what does feature represent? is it the feature layer name?
sorry I'm a beginner in javascript
KenBuja
<!DOCTYPE html>
<html>
  <head>
      on iOS devices-->
    <script>
      var map;
      require([
        "esri/map",
        "esri/graphic",
        "esri/tasks/query",
        "esri/Color",
        "dojo/domReady!"
        function (
              basemap: "streets",
              zoom: 8
                } else {
    </script>
  </head>
  </body>
</html>
IsraAlhamood
I still didn't get it.
here's my code:
var map;
function init()
     map = new esri.Map("mapDiv");
     var basemap: new esri.layer.arcGISTiledMapServiceLayer("link");
     map.addLayer(basemap);
     var content = "Hello!";
     var infoTemplate = new esri.InfoTemplate();
     infoTemplate.setTitle("<b>${BUILDING_NO}</b>);
     infoTemplate.setTitle(content);
     var featureLayer = new esri.layers.FeatureLayer("link",
     mode:esri.layers.FeatureLayer.MODE_ONDEMAND,
     outFields:["*"],
     infoTemplate:infoTemplate
     map.addLayer(featureLayer);
What I didn't get is what does feature o graphic(in the other code) suppose to represent.
I tried both ways and it didn't work.
IsraAlhamood
Ken,
It worked thank you so much.
KenBuja
Glad to help. Please remember to mark the correct post as answered. This will help others when searching on this question.
