Empty CSV File
2110
10-20-2014 07:21 AM
WalterDziuba
Published a feature service to ArcGIS Online with a .csv file attached. Although I can see the table in my map ie. column header, none of the values in the first column appear. I'm not using it for mapping purposes, but just to show a list of plants.
The .csv only has one column and 26x plant names.
Walter
Tags (1)
RuiSantos_EsriPT
Does your csv file has headers? It should have…
What is the name of the column? I recommend reading “Field naming guidelines” at http://resources.arcgis.com/en/help/main/10.2/index.html#//005s0000000t000000
What is your Encoding? I’m using Unicode (UTF-8).
Com os nossos melhores cumprimentos,
Rui Santos | Senior Account Manager | Educação, Cultura e Startups
Esri Portugal | Rua das Vigias,2, 1ºA | 1990-506 Lisboa | Portugal
T +351 217 816 640 | M +351 918 126 333 | [email protected] | esriportugal.pt
THE SCIENCE OF WHERE™
WalterDziuba
My .csv file does have one header called "NatVeg"
If it's just storing basic text, do you need to apply the Unicode (UTF-8)?
I'll try the unicode and see what happens.
Thanks for your reply Rui
Walter
WalterDziuba
Rui,
Saved my .csv to Unicode (.txt) and then used Notepad to save as (UTF-8).
But when I access my web map, the table is empty, although it still counts the entries it has which is 26x.
Walter
