ArcGIS for Desktop Cannot Connect Portal With Active Directory Sign In
9215
02-25-2014 04:29 AM
aykut_alpgirayates
We configure a Portal for ArcGIS with IWA (Active Directory sing in) and federate a ArcGIS Server with the portal. We can use the
portal on the browser users can sign in. Operations Dashboard also can connect to portal. However, we cannot connect to portal via
ArcGIS Administrator. The fallowing error occurs. " The URL specified does not appear to have a running Portal for ArcGIS ". The configuration of machine is below
Anonymous Authentication to default website is disabled from IIS
Windows Authentication is enabled from IIS
Arcgis server is configured to serve only https
Portal is configured to read AD from our server (on browser it works )
a certificate is bindings to 443 port is configured
Looking forward to hearing from you.
aykut_alpgirayates
Unchecking the �?? Check for server certificate revocation �?� worked for me. it is under Internet Settings / Advanced Tab / Under the Security Headding.
aykut_alpgirayates
SusanJones
Perfect.
Thanks awesomely for sharing this solution.
